LG DR-4810 DVD Recorder Logo
Question about LG DR-4810 DVD Recorder
Cannot record,screen shows: an err in HDD recording and playback is detected.
Posted by jdpetch on
5 Related Answers
Anonymous
SOURCE: LG RH177 Recording
once you have set timer record, you must then put machine in standby mode,once in standby mode you will have a little timer display in panel,should then come on when time to record
Posted on Oct 17, 2007
MGmidget
SOURCE: LG RH7796W DVD/HDD Recorder
The problem has fixed itself, thank you
Posted on Feb 27, 2008
aewins
SOURCE: Recording problem with LG RH266 Recorder..
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
Posted on Apr 19, 2008
Anonymous
SOURCE: No sound from LG HDD DVD recorder
Same Problem here, have not done anything yet, but I am convinced that it is due to blown Capacitors in the Power Supply......
Posted on Oct 11, 2008
Anonymous
SOURCE: LG LCD TV remote power button turns off LG DVD Recorder as well
Hi VMUZZI,
IT Seems that teh SIMPLINK Featire of your TV/DVR is ON. Try to OFF the feature.
Posted on Mar 18, 2009
What is the settings for playback?
There are no specific settings for playback on this machine?
If the lazer does not read discs and the display shows NO DISC or UNKNOWN DISC then the lazer pick-up needs replacing.
I believe that the lazer pick-up for this LG recorder has been discontinued?
1helpful
Trouble with my recorder on screen display show HDD Fail and when we try to play is blank what we must to do.thank you regard riyanto
The hard drive for the recorder is bad. That's why nothing plays during playback. The DVR can't get the video off the hard drive. You'll need to send the recorder in to be repaired and the hard drive replaced.
Recorder showing these words in window: ERR wish to restore it to folder index where I have important interviews filed.
The ERR indicator is only active if the DVR detects errors related to decoding of video/audio. These errors are due to discontinuities in the received or recorded file data.
9helpful
Screen shows ERR. I changed batteries and tried
You're right..This happens often when one changes the battery.Here's what to do :
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in ALL the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again.
Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
3helpful
4answers
I own a lg rh399h dvd recorder. I have finally figured out how to record from dvd to hdd, but it records in real time (slowly). Does anyone know how to :fast copy'' from dvd to hdd???
LG HDD/DVD RECORDER RH399H
Insert an empty DVD + R. The system asks whether to format - Format.
Select a recording on the HDD to copy to DVD.
Enter
Select dubbing
with arrows select type of recording to make (XP, SP, EP etc)
The system show the duration you can copy to you DVD. If small enough the FAST option also appears.
If big copies while playing the orriginal (I.e. playback speed)
JVC HDD Camcorder won't record or playback
Depending on what model number it is? My JVC had a snap shot feature to it as well as video. Make sure that this is not an option for your camera. There could be a possibility that you did record but you have it in this camera setting, it could be taking snapshots of what you recorded.
Dvr4-alert full screen playback
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do: You need to have a TV with Video in and Video out jacks.  Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
Error message
ERR-15 hard drive error. need to replace hard drive also it would be easier if you just take it in a repair shop
2answers
3helpful
2answers
HDD Corrupt
I have the XS35 and the HDD drive is curropt. Can I do the following?
1. Download the Toshiba firmware update:
http://www.tacp.toshiba.com/customersupport/model_firmware.asp?model=rd-xs34
2. Burn the ISO to a CD-R disc. ImgBurn is an excellent free burner for this.
http://www.imgburn.com/
3. Insert the CD in your unit. It will auto-install the firmware. Follow onscreen instructions. Takes about 10 minutes total.
After the update, my existing HDD shows are playable again, and I can record and playback from the HDD. I bet it would be a good idea to periodically backup your shows on DVDs, and regularly reformat the HDD.
Mike
[email protected]
Marvin
Marvin
Muzahura Frank
