Some TVs brands - I believe Proline is one of them - cannot be retuned when you are in Digital mode. If you switch back to analogue mode, then press the menu button, the option to auto-scan should be available. Once you retune, switch back to digital mode.
Try this and post back if you need further assistance.
Please rate this solution if you find it helpful. Thanks.
Obviously, if you are already in Analogue mode, switch to digital mode (press the button marked DTV/ATV on your remote to switch) then press the menu button. The option to scan/retune should be in the "Setup" menu.
hi proline lvd1985wd in digital mode does not display menu...tried re-scaning in analogue then switching back as you have said above, still not working....any suggestions
