Question about Ricoh IS 330DC Flatbed Scanner
When trying to use the scanner I get this error: Error 4144. What would cause this error?
Posted by jcomer501 on
CPCI
    Genius:
  • 1,325 Answers
What is 811 error?
You cannot repair this error easily. Most times its the main board that has the problem but its more than likely to be the scanner pcb than the main board. I am actually in the middle of the very same error and have tried the main board and it is the scanner pcb that is causing this particular problem. As you do not state what model you have , I cannot give you a part number.
Oct 27, 2015 | OKI Office Equipment & Supplies
Showing display on scanner error 13
This error is triggered if the scanner is not able to determine the end stop for the scanner. Likely an electronic failure but sometimes caused by too much friction in the scanner mechanism and the motor errors out trying to move the scanner.
Jan 18, 2015 | HP LaserJet M1005 All-In-One Printer
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
Error Epson Stylus Photo PX660 - Close the Scanner Unit
maybe the scanner rail of scanner has been stuck that's why when you turn on your printer there's an error!!! or if you can try to open the scanner and clean the motor and the belt.
it might dirt or something that causing your printer to turn it on or causes-sing error.
for my opinion plss.. check the scanner we have desame cases in my printer too. I open the scanner and clean it then it works..
Apr 27, 2014 | Epson RX595 Photo All-In-One Printer
Scanner Error - Power On Power Off
The "scanner warming up" error is usually caused by dirty glass or mirrors in the scanner assembly. Here is a link to a step by step guide that tells how to open the scanner unit and clean the optics to clear the error.
http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/
Feb 28, 2013 | HP LaserJet 3300 All-In-One Printer
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
Scanner seems stuck and causes error
you can always try to install the printer on a friend's pc as a test of the printer...do you have the install cd? if not try canon's site to download it.
Aug 10, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Ricoh IS 330DC Flatbed Scanner Logo
590 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
