Turn off and on the tablet, then make sure WiFi is on, click on search for conections available, if you broadband is listed select this conection and probably request the keyword password, enter the password, if not listed rebot your modern or broadband desconect fot 10 seconds and reconnect again. Check again in your device and you will see your broadband user name listed. Hope this information helps you.
once you have the mobile conection pluged into your ps3 try scanning 4 networks if it finds ur network click onto it and type in the WPA key that came wit your mobile conection
PLZ RATE THIS IF YOU FIND IT HELPED SOLVE YOUR CONECTION TANKS.
Router might not be set up with the modem. Your router broadcast wireless signal when it is powered on, so even if it is not connected to a modem(where you get your internet from)you will have a local connection. That's normal. You need to set up the router. Call linksys technical support, if they cannot help try http://technicalsupport.blog.friendster.com
Use the WiFi connection if you have a WiFi Router with your broadband connection , its much easier, you only set it up once, and you can move your PS3 wherever you want..all you need to do is configure the settings from your PS3 and will need your WEP or WAP Key from your computer's WiFi router. Look for it under Settings > Control pannel > Wireless Network Setup Wizard
Do you mean 3g mobile broadband , have you usb modem ore pc card. What is the problem ? are the software? ore are the conection to the nettverk?what sort of card and nettverk?
