Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage check for spark leakage in the dark.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
9. Improper valve clearance (too tight).
10. Check for generated diagnostic codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at
[email protected]. Good luck and have a wonderful day.
https://www.hdtimeline.com/threads/evo-backfiring-missing.15768/
https://www.mediafire.com/file/br4waxbyxcya9zk/84_to_99_Harley_Softail_Service_Manual.pdf/file
https://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/content/document/view?id=6392&groupId=16
https://www.6ya.com/ to speak to me personally
