You need to make sure your computer's display resolution is set to 1440x900, which is the monitor's native resolution. Other resolutions will result in fuzzy displays or, as you're seeing, distorted images.
Right-click on an open area of the Windows desktop (that is, not over any icons), then select "Properties" from the pop-up menu. Click the "Settings" tab and you'll find a slider adjustment to set the resolution. If 1440x900 is not offered as a resolution, you'll need to upgrade your video card (or add a video card if you have a motherboard with integrated video). Most newer computers support that resolution, but some older systems may only go to 1024x768.
Thanks for using Fixya!
