Question about Oregon Scientific Wireless IndoorOutdoor Thermometer with Atomic Clock Sync
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery, set it next to the outdoor receiver, nothing.
Posted by bbyrd1 on
iamtoddicus
    New Friend:
  • 26 Answers
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Posted on Jun 07, 2014
How do I get the -- away and get the outdoor temperature to work?
You may have to "reset" it by removing both indoor and outdoor unit batteries, waiting briefly, then reinstalling batteries in the outdoor unit followed by the indoor unit. After awhile, the outdoor unit should begin sending information to the indoor unit.
Nov 20, 2014 | Oregon Scientific Wireless Weather Station...
The putdoor temperature will not come in
Check batteries in outdoor unit and try moving to closer to the base station.
Apr 08, 2014 | Oregon Scientific Wireless IndoorOutdoor...
I See my Outdoor temp. Nothing
What do you mean nothing? How are the batteries? What channels are you using?
Feb 22, 2013 | Oregon Scientific BAR386 Wireless Weather...
ONLY SHOWS INDOOR TEMPERATURE DOES NOT SHOW OUTDOOR TEMPERATURE
I have a similar device and the instructions say to remove batteries from both units and wait for 10 minutes without pressing any buttons before installing batteries first in the remote unit then the indoor unit. The outdoor and indoor units have to "talk" to each other before getting in the mood to display temperatures.
Feb 03, 2013 | Oregon Scientific Wireless IndoorOutdoor...
I have model RMR682--Want to disable the Alarm--Please advise
The ice warning is normally only on channel 1. Just set wireless sensor to channel 2 or 3, then select that same channel to display on the base unit.
If you don't ever want to use the ice warning feature, then use channel 1 for a sensor that's situated indoors, then hope you never hear it!!!
Lee
Jan 11, 2012 | Oregon Scientific Wireless IndoorOutdoor...
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
Dashes in my outdoor weather reading of Oregon Scientific station
The signals are not being received by the main unit. Try to reposition the unit or move it to a different location. Also make sure the antenna is in the clear and not next to any thing like a cordess phone or charger as these can make RF noise that can block or cover the needed signals.
Feb 07, 2010 | Oregon Scientific Audio Players &...
Oregon Scientific Wireless IndoorOutdoor Thermometer with Atomic Clock Sync Logo
764 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
