Mitsubishi Master
- Posted on Oct 20, 2010
Re: My mom wanted her dvd hooked up so I tried to channel...
first, do you know how to successfully hook up a DVD to a TV? It might be that you did not connect the DVD to TV correctly or the Video cable might be defective or failing.
Please crosscheck the below procedure on how to hook up a DVD player to a TV:
Check
all the input ports located in back of the TV. It needs to have at
least composite ports, which are the three round sockets colored
yellow, white and red. It could also have an HDMI port (it looks like a
small, stretched trapezoid) or component ports (similar to composite,
but colored blue, green and red).
Disconnect
the cable/satellite receiver from the TV only if it is using the TV
input port you want to use for the DVD. If this box is connected
through an RF coaxial cable (the thick black cable that is twisted into
place), you don't need to disconnect it.
Connect
the DVD player to the TV, using the best cable connection available. An
HDMI cable will transmit the bast video/audio combination. If you can't
use this, the composite cables (yellow, white, red) will also carry
both video and audio. Component cables (blue, green, red) may give you
the best video quality but won't transmit audio.
Connect
a cable to the DVD and TV for audio if you connected the video with
component cables. The simplest connection will be through composite
audio cables. This means you only need a cable that has red and white
plugs.
Attach
your cable or satellite receiver to the DVD's input, if it has one. You
should only need to do this if you are using a DVD recorder instead of
just a player. If the DVD recorder has an RF coaxial port, use that.
Otherwise, link the cable/satellite's output to the DVD's input through
composite cables.
Reconnect
your cable/satellite receiver to the TV if you had to disconnect it
(Step 2) and did not connect it to the DVD's input (Step 5). Using the
RF coaxial connection is your best option.
If reverse is the case, please let me know.
Good luck.
the tv is a big screen I disconnected the dvd no channel will display .When I turn tv on it says cable 1-69
it's like the tv needs to be re programed
