SOURCE: need to restore acer to factory settings
just boot from your backup disk. it will guide you to reload the Operating system (factory default).
FYI, if you haven't delete the recovery partition, you can use alt+f10 to reload. just press alt+f10 during boot.
SOURCE: ACER NETBOOK MESSING UP NEED TO RESTORE IT BACK TO ORGINAL FACTORY MODE
reboot and hit the alt and f10 buttons at same time and follow the prompts
SOURCE: Acer Extensa 4620
alt+f10 push together. if the restore files still working it will start automaticly. if files are broken down acer doesnt support this in warranty. you need setup xp or vista manuelly.ç
sorry for my english have a nice day.
SOURCE: acer extensa 4630z windows complete restore
I wrote to Acer myself about this and this is their reply.
The
other way before Vista starts up is to tap ALT + F10 (at the same time
repeatedly) when the computer is first switched on.. The window of
opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then
it indicates that you have tapped the ALT + F10 correctly, and all you
now need to do is press “Enter” and the Recovery program should load on
your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
SOURCE: acer aspire 6920 back to factory settings
Acer sent me these instructions.
The
If you see this:
Then
