Samsung S630 Digital Camera Logo
Stacy De Los Santos Posted on Oct 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the samsung s630 and i have taken some pictures on it before i got a memory card. i want to save them to my memory card, but when i insert the memory card those photos wont show up. how do i get those photos to save to my memory card? also i accidently locked some of the pictures on the camera that i want to delete. how do i go about unlocking them? thank you!
Anonymous
Level 3:
Genius:
  • Master 1,177 Answers
  • Posted on Oct 20, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1177
Questions
0
Helped
219918
Points
3782
If you remove the card from the camera and connect the camera to your computer with the USB lead, you should see the camera's internal memory as a disk drive on the computer. If there is a memory card inserted, you will see that memory instead.
Unlocking individual pictures is done with the same function that locked them. It is probably on a menu available when you are viewing the pictures on the camera.
Have Samsung S630 Do not have disc o download pictures in omputer Does not recognize camera
Consider getting a card reader instead. Once the memory card is inserted into the card reader, the card will appear as a disc and you can simply drag-and-drop your pictures like any other file. It will also be faster than going through a USB cable.
2helpful
My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
Card lock.?
Friend dont worry it so simple
Insert u r card into card reader and then change its format
Up to
Fat or Fat 32 Into NTFS and format it if it is formated then it will be ok
1helpful
Memory card
Each time you press the shutter button and a picture is taken, it is automatically saved on the memory card inserted. The same happens to videos.
Memory Card
If you transfer the photos to your computer from the camera, you should be able to save to another memory card. I can't say whether or not the photos on the new memory card will show up on your camera since there may be certain requirements to display on camera screen.
Plug your camera into the computer USB or insert old memory card. A box should pop up giving you the option to view files. Copy and Paste (or Drag) selected photos to a specified folder on your computer (Like My Pictures in My Documents). Insert new memory card. Copy and Paste (or Drag) selected photos to the drive for your memory card.
1helpful
Samsung s370
I'm willing to help you out on this.
Basically, there is no settings for picture storage on your camera.
Once you took pictures WITHOUT a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures WITH a memory card, all pictures are just saved on the memory card itself.
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
3helpful
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
- Turn on camera
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Samsung s630
About the memory cards to be used with this camera, those could be:
- MMC / SD card (Up to 2GB Guaranteed)
- SDHC card (Up to 4GB Guaranteed)
Some cards are not compatible according to the memory card
manufacturer and memory card type.
If that is the case, i'll be advising you to try 1 GB so it will work.
But if it still does the same thing with the 1 GB card or with whatever cards you're using, you could still take more pictures even without a memory card. It's just that you need to adjust the picture size and quality to the lowest resolution to have more pictures taken.
To change the size:
Rotate the mode dial to PROGRAM:
- Press +/- button (2nd button)
- Go down to where you're see 6M, 5M, ... 1M
- Select 1M for the lowest size
- Press MENU/OK to save changes
To change the quality:
- Go down to where you're see Dots corresponding to NORMAL, FINE and SUPER FINE
- Select NORMAL for the lowest quality
To turn off camera after the settings
have been changed to refresh the camera.
If it still does not work, you need to contact the Manufacturer.
I hope this help you a lot.
Sandisk is On card lock???
The card probably needs to be formatted for your camera but that will erase the pictures already on the card. Far as I know each card must be formatted to the camera for which it is to be used. Use the menu button to find format. (Last icon, "wrench2", format is toward the bottom of the list. Remember you will lose the pictures already on the card, so save them first.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
