Question about Panasonic KX-T7630 Corded Phone
How do you transfer to voice mail? - Panasonic KX-T7630 Corded Phone
Posted by morgan931 on
Carl Navarro
  • Panasonic Master
  • 2,460 Answers
With a VM Transfer button. Assuming you have a Panasonic brand VM and the access code is 500, you program one of the 24 buttons to dial 94500 (the sequence PROGRAM button 94500 STORE). Now, when you're on a call, press the VMT button and dial or press the extension DSS and hang up.
Carl
Posted on Oct 20, 2010
Voice mail not working
The Voice Mail system provides the voice mail service based on the existing network. When a call is transferred to the VM system, the system asks the calling party to leave a message for the called party when the called party is busy, powered off, or out of the service area. It provides voice mail, call prompt, and voice short message and email. By adopting VM service, operators' system put-through rate, service usage rate, customer satisfaction, and revenue can be improved.
Aug 20, 2013 | Panasonic KXDT321 Phone
How do I get an extension on the main console to go directly to voice mail.
Hello Friend,
Click on this link(it may take few minutes to load according to Connection speed) and you will get Helping Guide for your Product...If you want to get Feature Codes ,then go to Page 9.OR to Call directly to another User's Voice mail/Transfer a Call directly to another User's Voice mail-See Page 13 for Detailed Information.
  • Press programmed Direct Voice Mail Button/Press Feature Button and Select Direct VM[DrcVM] OR Dial 56
  • Dial the Extension whose voice mail you want to Call/Transfer a Call;you can Use Programmed AUTO DIAL Button OR a Directory Listing too(See Page 11,14)
There is Possible to just Click on the Index data as you need... Hope This Lead you better Conclusion....Thanks for Contacting FixYa...
May 27, 2010 | Lucent Merlin Legend MLX-20L Phone
How to turn on Voice Mail again.
You phone is no longer forwarded to the voicemail pilot number. It should be forwarded in a no answer condition and a busy condition.
Mar 11, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Callers are not getting transferred to voice mail when I can't answer my blackberry pearl 8100
This might happen's because the voice mail number in you're Handheld might be wrong, Please check with that.
If the number is correct you your call will be transfered to voice mail, If the voice mail number is wrong then you need to contact you're service provider.
To find the voice mail number follow the step's:-
1) Go to call log.
2) Press menu key.
3) Select Option's
4) Select voice mail.
I hope I was able to help you today.
Thank you for using Fixya.
Nov 01, 2009 | RIM BlackBerry Pearl 8100
CAN'T TRANFER CALLERS TO VOICE MAIL
A Panasonic system and Pana branded voice mail has a VM Transfer key that lets you send a caller to voice mail. It's programmed by picking a button down the left side of the keystrip (CO) and pressing PROG, the button, 94+ the VM extension, and STORE. (In a TA-824 system it would be either 107 or 115).
The TRANSFER button would work if the extension has CF set (All Call or Busy/NoAnswer), but there would be a delay. At the very least, when you tried yours, you were either dialing the VM extension which is probably not vailid because it won't let you transfer to yourself, or an invalid extension.
Carl
Jan 27, 2009 | Panasonic KX-T7730 Corded Phone
I CAN'T TRANSFER CALLERS TO MY VOICE MAIL. I PRESS THE "TRANSFER" BOTTOM AND MY EXT BUT SCREEN SAYS "NOT VALID"
Most phone systems will not let you transfer to voice mail if you are on the extension that you want the voice mail to go to, which is the reason for the "Not Valid" message.
The logic is, if your talking to them on the phone, why would you want them to leave a message on your voice mail. Your talking to them directly already.
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
DKT 2020 ST
The phone needs to be fowarded to voice mail. go to the phone press intercom# 604, dial the voice mail extension number , press the speed dial button, enter 16 for time then press redial
Sep 15, 2008 | Toshiba DKT-2010 Corded Phone
It rings 20 times before voice mail comes on and they can leave a msg.
You are asking questions about your Toshiba phone system and the voice mail system attached. You could have one of several different Toshiba phone systems and several different voice mails.
The system has timers for things like "No answer transfer timer" and also rules for what it does at that point. (transfer to voice mail box, transfer to voice mail branch, transfer to the operator.. etc..) It can get very complicated. Most likely you are just dealing with the no answer transfer timer for your specific phone port but even just changing that can be very complicated. Many Toshiba phone systems need to be programmed from a computer using specific software. If you do not have someone in the company that knows how to make simple changes to the phone system you would need to get a phone system installation company to make the changes. Hopefully you know the company that installed the system??
Nov 09, 2007 | Toshiba DKT-2010 Corded Phone
Call will not Transfer to Voice Mail
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it. This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail. I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail. Did you set this up yourself? How did you program the phone system?
Aug 21, 2007 | Toshiba Stratagy 4 Lite Voicemail System...
Panasonic KX-T7630 Corded Phone Logo
107 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
