Question about Dewalt 18v Nano Cordless Impact Driver Drill Dc827
When I bought this item it stated that you could fix sockets onto the end of Impact Driver. I am unable to see how they fit onto the end of Driver. Is there an attachment made for this purpose? Thank You Gwyn
Posted by Madmonk on
Kyle DeLory
    New Friend:
  • 18 Answers
Yes there are adapters that have the 1/4 inch quick connect that will fit into an impact driver or secure firmly in a drill with chuck. they will come in either 1/4 inch, 3/8 inch, or 1/2 inch drive you can easily find these at just about any hardware store like lowes or home depot or if you don't mind waiting a couple days amazon has them for just a couple dollars for all 3
Posted on May 28, 2016
durikniz
    New Friend:
  • 34 Answers
You have to distinguish between Driver and Wrench. Driver has 1/4'' hex hole where you can insert standard bits. Wrench has a 1/2 or 3/8 Square drive and you can put sockets directly on it. Wrenches have usually higher torque compared to drivers. DC827 is driver, you might want to change it for DC822, or you can use adaptor from 1/4 to 3/8 or 1/2 Juraj
Posted on Oct 20, 2010
Can the water pump housing be removed?
If there's enough room for a socket - try an impact socket on the rounded off bolt. An impact socket can be hammered on to fit and grip.
The cover doesn't come off a water pump. It's a sealed unit.
26072391-5gult0ot5kkhyupfos0rfps2-1-0.jpeg Impact sockets. Hammer one onto the rounded off bolt head
Jan 28, 2016 | Cars & Trucks
I Have a Husqvarna model 232 (Year 1998) strimmer which I bought a new clutch for it but I cannot figure out how to remove the old one, Do I need a special tool ? If not anyone able to help me ? Many...
The clutch is threaded onto the end of the crankshaft, with a normal right hand thread, there should be a 19mm nut on the outside to fit a socket, you then just jar the clutch against the compression of the saw until it spins off, if you have an impact gun this will take it off in seconds.
Sep 15, 2011 | Garden
I have just bought a Bosch GDS 18 E Impact Wrench second hand. My question is how do i keep the socket from falling off the anvil.
A hand ratchet wrench uses a ball to hold the socket on the shaft. Impact wrenches use a ring. The ring is needed for the high speeds.
There should be a groove on the end of the socket end. That groove should have a round or flat ring in it. That ring keeps the sockets from falling off. It is missing go to Bosch for a replacement.
Jan 06, 2011 | Garden
What sockets fit
Any sockets will fit the ratchet, 3/8 drive, the impact drive is 1/2 drive, and they make hardened sockets for it. And I can't really make out the last tool there in the kit. The impact tool will take normal sockets for reg duty use but not for wheel lugs and such, they will crack, but if you buy Craftsman, they will replace it. I have only cracked one in thirty years. But I also have the hardened set of sockets. Hope this helps.
Jun 25, 2010 | Craftsman Mechanics Air Tool Kit Impact...
Dont know where to put oil in Craftsman 1/2 " Impact wrench
I just bought one of these also. Manual says oil goes into "the air inlet" which I'm thinking is where you attach the hose. That way the oil is sprayed throughout the interior of the gun once you run air through it.
Question for you: I can't get an impact socket onto this gun, almost seems like the square hole is too small. (yes, both are 1/2" drive). How do you get a socket on this stupid thing?
(man that sounds like I'm an idiot, but I've spent a half hour leaning all my body wight, wiggling, etc. and can't get a damn socket on)
Apr 29, 2010 | Craftsman 1/2" Impact Wrench
My impact wrench wont engage to the socket.
I have the same problem, brand new impact wrench, brand new impact sockets, but can't get a socket onto the gun. Leaned on it with all my weight, wiggled, nothing. and yes they are both 1/2" drive. WTH?
Nov 21, 2009 | Craftsman 1/2" Impact Wrench
TROUBLE FITTING NEW BELT
i put the belt on large wheel then with a large Phillips screwdriver
though a socket slightly larger than the motor wheel put the belt around the socket on the screwdriver and put the driver in the small
hole in end of the motor wheel,lever the belt and slide the socket with the belt on down to the wheel ,push the belt over the socket onto the
motor wheel this my take 5-6 atemps but ive done it about 5 times
Feb 05, 2008 | Washing Machines
Dewalt 18v Nano Cordless Impact Driver Drill Dc827 Logo
251 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
efs_perpends
efs_perpends
Mike
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
