Try the fix here http://www.gamepatchplanet.com/game.php?name=cossacks_the_art_of_war
SOURCE: I've installed Cossacks{the Art of War} in Windows
Right click on the program. Then navigate to compatibility, then select the compatibility operating system the game is supposed to be played under. Also, after you select xp sp3 or whatever you need go ahead and check the box that says "run as administrator." This will run the game under the proper drivers needed for that game to run properly.
Please rate if this helped :)
You can give this a go too...
http://m0001.gamecopyworld.com/games/pc_cossacks.shtml
Windows Vista or Windows 7, will have problems running some older versions of applications, just because so much has changed under the hood from Windows XP days. Thankfully there is a compatibility mode that can be easily set per application.
To configure the compatibility mode for an application, just locate the installation directory and right click on the .exe, selecting Properties from the menu. THEN select your compatibility tab, You can choose to run the program in Windows XP compatibility mode, or even all the way back to Windows 95 compatibility.
Probably the most useful setting to start off with would be to disable the visual themes and desktop composition, if you can't get things working. If you are trying to run a video game, you will often need to choose "Run this program as an administrator". You'll have to play around with it, but most likely you can get your application working this way. Also, you will be able to make a selection for windows VISTA which is backwards and forwards compatible with WINDOWS 7
