Question about Car Audio & Video
I have star vision 10" car tv monitor it need the male cable for the female onne with the pins to go into
Posted by donjuan17320 on
Ronnie Wilson
  • 1,596 Answers
Radio Shack Has All You Need
Posted on Oct 20, 2010
WHAT IS THE PIN CONFIGURATION WHERE SUPPLY CORD PLUGS INTO REAR PANEL OF MONITOR?
There is no wrong way to plug in the cables into the monitor.
If you're referring to the male/female cable ends... you will always need a male to male cable from a monitor to a device.
25616839-cbt13vi4zbmnff1d5zdl02jb-2-0.jpg Or DVI:
25616839-cbt13vi4zbmnff1d5zdl02jb-2-1.jpg Need any more help? Reply!!
Mar 30, 2015 | Balance CM2019 19" LCD Monitor
Install external monitor from desktop to laptop
If your laptop does not have the 15 pin plug (VGA Port) then you will need to get some type of adapter that will make the monitor work. You probably have a DVI monitor.
You just need to make sure you get the correct type of adapter and make sure the ends that plug into the computer are correct such as male or female. For example think of the human male and female body parts when you look at adapters. The vga port on the computer is called a Female port, but the piece that plugs into it is called Male. It's the same with DVI ports.
I think you need a VGA Male to a DVI Female so below is a link to one and for $2.54 from Cable Wholesale.
http://www.cablewholesale.com/specs/dvi-to-vga-cable/30dv-05300.htm
Below is a picture of what it looks like.
Jun 03, 2012 | Dell Computers & Internet
How to install external monitor to laptop if laptop does not support 15 pin plug from monitor
Jun 03, 2012 | Dell OptiPlex 780 Desktop Computer 1 x...
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
http://en.wikipedia.org/wiki/VGA_connector
More information on the DVI connector styles, and the Digital Visual Interface technology,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
How to connect laptop to Panasonic TV LCD TX-L42U2B
Laptop to TV hookup all depends on what the laptop has for output to a monitor and what the TV has for input. Your laptop should have a monitor output, a 15 pin female jack. You need a cable (male to male) with these 15 pin connectors at each end to hookup to a TV with a PC input jack. For the audio, use a 3.5mm stereo audio cable. Hookup from earphone out on the laptop to the TVs PC audio input jack. If the TV has no PC input jacks, there are other ways to connect. See this link:
http://columbiaisa.50webs.com/laptop_to_tv.htm
May 18, 2011 | Televison & Video
Changing cable port
The monitor is a Fujitsu VL-15DX5G. 15 inch LCD.
The monitor cable uses a female DFP20 connector.
(Display Port 20-pin)
http://auction.thumbnail.image.rakuten.co.jp/@0_auc/image50/cb/4a/00010523850/a1/85/img00149858603.jpg
So you need a male DFP20 to male DVI-D adapter, or adapter cable.
DFP20 Male to plug into the monitor cable, and Male DVI-D (Dual) to plug into the graphics card's, female DVI-D connection.
So far, all I have found from a quick search is a Male DFP20 to Female DVI-D adapter, such as this example,
http://www.worldofcables.com/store/viewitem.asp?idproduct=768
Of course this won't do.
IF, this is all that's available for DFP20 adapters, you'll need an adapter of Male DVI-D to Male DVI-D, also. (Yes, I am aware of how crazy that sounds)
(It would appear, adapters are sold to connect a normal DVI-D monitor cable, {Male}, to a computer with a female DFP20 connector)
Should your searching only find DVI-D female to DFP20 male adapters, or adapter cables, then here is an example of a DVI-D male to DVI-D male adapter,
http://www.kvconnection.com/product-p/m-sgc-dvid-mm.htm
(DVI-D male to DVI-D male cable would probably be better as there would be less strain on the graphics card's DVI-D connection)
May 14, 2010 | Computers & Internet
Can't connect my emachine to 50" samsung plasmatv mod#pn50B530S2F
try going to "display properties" and adjusting the settings there. Right click on the desktop wallpaper and go to properties, then click on the settings tab. Make sure the TV setting is turned on
Mar 28, 2010 | Acer Aspire L100 PC Desktop
I have an MSI motherborad model MS-7366 and I need to plug a DB9 male to 10 pin header pc blanking plate I just need to make sure I am pluging it in the right place
LOOK AT THE ROWS ON PINS ON THE PLUG IN CABLE ,THAT THE MALE END. AND THE LABTOP HAS THE FEMALE END AND IF FOTH LOOK THE SAME THAN PLUG IT IN, BUT THE MALE END MAY NOT HAVE ALL THE PIN LIKE IN THE FEMALE PLUG LOOK LIKE THAT OKAY
MAKE SURE ALL THE PINS ARE STRAGHT
CANDYMANGANDY
Jan 28, 2009 | Intel Motherboard
I'm trying to hook up a PC Monitor to a DVD Player. 15 pin on the monitor and component and HDMI options on the DVD Player. What adapter / cable do I need? Thanks, Paul
I would try Ebay .. sounds like ya need a DB15 Female to HDMI Male.
OR a DB15 female to DVI male plus a DVI female to component/HDMI
The link below should give ya some idea...
http://search.ebay.com/DB15-Female-male_W0QQcatrefZC6QQdfspZ32QQflocZ1QQfromZR40QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZQ2d1QQsaslcZ2QQssPageNameZRC0021QQ_trksidZp1638Q2em120
Jul 28, 2008 | Televison & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
