Question about LG Dryers
E3777W dryer does not spin, but does produce heat
  • 3,074 Answers
This website will help Tim;
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Oct 20, 2010
6ya staff
SOURCE:
Kenmore dryer he2
It could be the belt that spins the dryer is slipping, probably needs to be replaced.
Jul 22, 2014 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
My dryer stopped heating. Help!
Heating element sounds like its gone out
May 21, 2013 | Dryers
Dryer spins but does not produce heat
Did you see if your dryer element went out then you get no heat at any time that you run it.
Dec 31, 2012 | Kenmore Dryers
I looked through the peep hole in front of my gas dryer and I don't see anything lit.Dryer spins great, but doesn't heat up. What is the problem?
Igniter - The dryer's igniter is what ignites the gas that has entereddryer-ignitor.jpg through the gas valve. It will glow red, then when it reaches a certain temperature, it will trigger a thermostat that opens up the gas valve and that's when the dryer starts to heat the air. If the igniter has failed, the motor will still run but not produce any heat.
Jan 31, 2012 | Whirlpool Dryers
Dryer spins but wil not produce any heat to dry clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 16, 2010 | Frigidaire GLER341A Electric Dryer
Why won't my LEB 6300 produce heat? It spins just
unplug remove the back, the heater box is to your right,the heater box fuse is on the left side top check it with your meter,the heater box element is on the bottom remove the 2 wires and check with meter,iam sure it is one of the-mike
Feb 21, 2010 | Whirlpool LEB6300 Electric Dryer
My dryer spins and heat just a little but not enough to dry any clothes
Need to change the heater filament. The heater filament has several portions to produce heat. As it ages, some portions are not producing heat anymore hence the total heat produced by an old filament can not put out as much as originally designed.
Jan 08, 2010 | Estate EED4300TQ Electric Dryer
Gas Dryer with no heat or timer
Check the following
http://www.youtube.com/watch?v=rQV-z4f7fvA
If you need more assistance don't hesitate , e-mail us back.
Thank you Was this helpful ?
May 13, 2009 | Whirlpool Dryers
Gas dryer lgr4634eqo GAS
check the thermal fuse located at the back of the dryer for continuity and let me know how you make out
Sep 13, 2007 | Whirlpool LGV4634JQ Gas Dryer
Dryers Logo
Top LG Dryers Experts
jimorris77
John Tripp
John Tripp
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
