The "F0" fault code is indicating a shorted OFF key pad. A technician would determine if the problem is the Key panel or the Control board by disconnecting the ribbon connector and measuring the flat cable pins 13-14. It should be open and should measure between 100-150 ohms while pressing OFF key.
He would disconnect power to range before testing the key panel.
I recommend calling a service technician to diagnose and repair your range
SOURCE: Ge Electric Double oVen
This may be related to a problem I have helped others solve. The solution is available free at my website. I have at last count helped over 1000 oven owners with a similar problem. http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Hope it works for you too.
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
SOURCE: JTP56 Double Oven Beeping and Display FO Code
http://www.fixya.com/howto/h155060-dreaded_f7_error
SOURCE: I HAVE A KENMORE DOUBLE WITH FO AND BEEPS HOW DO I
Try this first! The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
SOURCE: Kenmore double oven keeps beeping and shows error
Hello there:
F0 or F1
Failed transistor in control
If code cannot be cancelled,
replace the Electronic Range Control (ERC) or touch pad
