SOURCE: Cannot preview shots in lcd with new Canon Rebel xs 1000d
There are two modes to the XS's Live View system, selectable via
Custom Function 7. Live View is disabled by default, by the way, so
you'll need to find this menu item in Settings Menu 2 to turn it on.
The two options are called Quick and Live modes. Quick mode works as
most Live View modes do, dropping the mirror when you press the AE-Lock
button (marked with an asterisk) to use the conventional phase-detect
autofocus system. This temporarily blacks out the Live View image,
which makes it impossible to know that you're still framing the subject
and holding your AF point in the proper place.
That's why they added the second mode, which they call Live, but is better
described as contrast-detect autofocus. This works just like a digicam, reading
the image from the imaging sensor while adjusting the lens for the setting that
produces the most contrast in the image. A small square appears in the center
of the image area, and you can move it around with the cross keys. Just like
Quick mode, unfortunately, you have to press the AE-Lock button first until
you hear the focus confirmation beep, then press the shutter button to fire.
It's a little slower at times than phase-detect mode, but it gets the job done.
Live mode is really better for tripod work, where you can place the AF area
right where you want it and confirm focus onscreen.
Both modes offer the ability to zoom in on your live view, excellent for confirming
focus before capture. Using the Magnify button just right of the AE-Lock button,
you can zoom in 5x or 10x, then press the AE-Lock button to focus if you like;
but of course you can't confirm framing in that mode.
SOURCE: Canon Rebel XS displays busy signal after I take a
Is your card nearly full? Is your battery fully charged?
SOURCE: View finder displays "busy" and the shutter is half open
I can help you fix the BUSY Error or Error 99 of your Canon EOS Digital Rebel XS.
Installation of this Canon EOS Digital Rebel XS firmware version 1.06 update will solve these problems:
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
I hope that helps.
SOURCE: "BUSY" Problem
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
SOURCE: When I take a picture with the Canon Rebel, it
Good day,
The problem you might be having is that the view finder is out of focus.
If this is the problem it is an easy fix.
You will see a small wheel next to the view finder (it has a + and a - next to it), look through the view finder and let the camera focus on an object. Now turn the wheel and you will see the image either get worse or start to come in focus. Adjust the wheel until you are satisfied with the clarity.
Please let me know if this was helpful!
Regards
