Question about Toshiba SD-V291 DVD Player/VCR
Assuming you have power to the machine , i would suggest the ejection drive belt has stretched , 2 choices here , take it somewhere and get it fixed or unplug it from power supply and remove the top casing yourself and have a look.
Posted on Jan 29, 2018
SOURCE: This machine plays DVD discs fine but can only hear the sound with VCR tapes
there is a trick to clean the vcr heads, use a dolar to gentely rub the heads but be carfull if you dont do very gentel can break the head, apply little presure to the head with a dolar in your finger and move the cilender back and foward, not the dolar...good luck
Posted on Jul 27, 2006
SOURCE: DVD RECORDER + VCR
this shows that your tape needs to be cleaned we have vhs cleaner a liwuid type and dry type just play this and it will clean your tape head. the tape is stock up inside due to dirty tape head. does this answers your problem?
Posted on Dec 03, 2007
SOURCE: VCR thinks ALL tapes are write protected.
the record tab detection switch inside the machine is broken
Posted on Dec 13, 2007
SOURCE: Toshiba D-VR4XSU hi-FI VCR & DVD Video Recorder
Are you on Recording Mode ?
T.REC is Timer Recording Mode
VCR stands by for recording. During timer recording standby mode,. the VCR normal operation should not be
used (messes the recording). That's why it's asking you to cancel it.
Posted on Aug 26, 2008
SOURCE: Playback Problem
open the recorder, 4 screws at each corner, wipe the playing head and the voice reccognition head, to the right of the playing head head with a baby wipe, you will be amiazed what **** comes off it. DON'T scrub it just wipe lightly, spin the playing head so it's clean. If you have a lint free cloth ( a glasses cleaning cloth you get in the case is brilliant) Try the tape (before you put it in make sure everything is DRY!) and your problem should be solved. It worked for me! and that came from a TV engineer
Posted on Jul 15, 2009
sounds like ejection mechanism drive belt has stretched and needs replacing.
