Computers & Internet Logo
Posted on Oct 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hooking up the Wii to the cable modum, what all do I need for Netflix to work ? I hear I need a wireless router, do I need more than just a wireless router.
Anonymous
Level 3:
  • Master 2,229 Answers
  • Posted on Oct 19, 2010
Anonymous
Master
Level 3:
Answers
2229
Questions
Helped
563841
Points
6804
What people use is a Roku box and a wireless router.
You can stream the Netflix movies from the wireless router to the Roku box which connects to your TV. There are some new TVs that have built-in wireless adapters and in that case, you don't need the Roku box.
2answers
I can't get connected to Netflix.All that pops up is error code 209826
Error code 209826. Is this with a Wii? Error code references "Problem connecting to the Wii Shop channel. Either a problem with the router or the Wii Shop may be temporarily
down. Try again later."
I recommend turning off the Wii completely. Check the wireless router and unplug the router, but do not disconnect the cable. Keep powered off for 5 minutes. Plug router back in, let all the lights power up and then turn the Wii on and attempt to connect again. Should the issue continue, you may need to go through the Wii network set up and verify that it is communicating with the router.
Dec 30, 2014 • Netflix
Can u have netflix on your wii without having wifi???
You don't need Wi-fi specifically, but you do need an internet connection. If you do not have a wireless router, you will need to purchase a Nintendo Wii LAN adapter. This allows you to connect the Wii to a wired router using an Ethernet cable.
I want to hook up netflix to my computer ,thru a wireless router.My computer is running of a land line .Do I need a two way spliter to run my Ethernet cable to both the computer and router,to run properly?...
Does your computer have a Wireless Adapter? This would allow you to pick up wireless transmissions from your wireless router.
If you don't have a Wireless Adapter, you'll need to buy one, or, you can connect your computer to the router with an Ethernet cable and then connect your Router to the socket in the wall.
Either way, as long as you have internet access on your computer, you will be able to hook up Netflix.
Trying to connect to netflix via Wii: error message code 51030> Unable to find an access point. Please confirm the SSID and try again.
You need first to have a wireless router for your wii to receive a signal, once this is set up you need to call your cable provider for the ssid#. This will link your wii to the router so that you can access internet/ netflix. Another way to do this if you don't have a router is to connect your wii directly into you bradband modem using an ethernet cable. I hope this helps.
My Wii was connected to netflix through my internet before and now keep getting error msg. Called netflix and it shows Wii is activated on their system but is not now connecting to my wireless router...
1. Attempt to relink your Wii to your router from the wireless menu in the Wii.
2. If (1) above does not work, you can reset your router to factory settings then attempt connection again. BEFORE doing this, hook your Wii up to the router with an Ethernet cable to make sure you have a connection and not a problem with your wii.
3. If you decide to do a hard reset, go to the Cisco/Linksys website for complete reset instructions.
http://home.cisco.com/en-us/wireless?referrer=www.linksysbycisco.com
2answers
Netflix not working, this is the message on my TV. An internet connection is requried Configure Internet settings now? Quit Enter...
you need to have you r wii connected to the internet in order to get netflix. you can connect to your existing internet by wireless or by an adapter like this one clarkcanhelp_5.jpg
if you go wireless, you will need to use a wireless router.
hope this helps
Hooking D-Link 655 to a Ambit Cable Modum with Charter Cable, Cannot Get it to Configure. When modum is directly plugged to modum internet is fine, but I cannot get throught he setup stage when hooking the...
I have dlink 2100ap wireless router any body had access my wireless network but i want to ristrect network just like network passkey how can i give my dlink 2100ap wireless router pass key please give me reply
Loose connection
  1. Update the Firmware on your router.
  2. When you lose internet, look on your modem and make sure that no lights have gone out. (i.e. Cable) If this one goes out, it is your provider.
Grand Canyon Tech
Grand Canyon Tech
