Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
Posted on Oct 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i tune my cobra 29 - Cobra 29 WX NW ST 40-Channels Base CB Radio
Anonymous
Level 3:
Guru:
  • Master 773 Answers
  • Posted on Oct 21, 2010
Anonymous
Master
Level 3:
Guru:
Answers
773
Questions
0
Helped
268905
Points
1659
Depends on what you mean by "Tune"
If you are talking about aligning the radio, you need the factory service manual, a watt meter, volt meter and oscilloscope to align the radio.
If you are talking about a peak and tune, that all depends on what you want. If you are just trying to peak it out, the easiest thing to do with out having to know about what you are doing is to turn the modulation to max. In that radio you do that by turning VR4 all the way to the left. That will get you around 20 to 25 watts of modulation.
There is more you can do, but it gets technical. But over all you will be pleased with just the modulation increased.
Some times people have the radio tuned to be run on an amp, which is necessary so that you do not blow up the amp. This involves un-soldering parts and replacing them with other parts to achieve the desired dead key.
1helpful
Mods for Cobra 29LX max ?
Manuals in the link tell you how to tune. What kind of 'modifications'?
https://www.google.com/search?q=Cobra+29+LX+max+manual
Were is the tuning pod on a cobra 29 lx chr le
there are many tuning pods ,which one do you need? modulation is vr-4
Cobra 29 LX LCD tuneing
brand new out of the package don't need tuning. just turn up the power a bit to 3.8 - 4 watts and modulation set at 95% and you will be fine.
Were is the tuning pod on a cobra 29 ltd for more power output ?
how much power do you want? 4 watts is the max other than that those people that were splashing you will now be splashed by you.
1helpful
I am looking to find out what wire to cut to push more amps out of a cobra 29.
Well I think you mean watts, try this, cut D11, then tune L12,L13,L14....hope this helps....
Just bought a workman 3000 to 7500 watt cb antenna, ever heard of it?? Im going to hook it up at work monday, got a cobra 29 ltd + or - 30 watt output. 9' coax. the antenna has 8" of swr adjustment... for...
cobra 29 has a 12 watt final, doubt you will be doing 30 watts. 25 if your lucky. Use 18 feet of coax, you will get better broad band.
If the antenna comes with the whip in it already, its been tuned at the factory and you shouldn't change it yet.
If not, half way is okay. It still needs to be tuned on a meter. either the one in the radio or an inline.
My cobra 29 has a 75watt amp on the back how can i get more
If you're using the RFX-75 amp section. Then you'll need to make sure your transmiter section is tuned for full output. The last last unit I installed in a Cobra 29 LTD, the radio modulated right at 100 watts output.
Hope this helps,
J.R.
2answers
Cobra 29 is one channel off, ch 7 is on ch 6 and so on
The radio needs to be tuned.  This should only be done by a licensed repair shop.  You will spend less money taking it to a shop than you will buying testing and tuning equipment needed to do it yourself, which would void the warranty.
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
