Question about Gestetner - 5502 Digital Imaging System Copier
Looking for codes sc360 and sc990 gestetner 5502
Posted by copysolution on
gggg
  • 904 Answers
Sc360 is a hard drive detection error. The hard drive might be either defective or disconnected, or one of the connectors might be loose. If you know the hard drive is good, check its power and data cables and connectors. In rare cases, this error can point to a faulty BICU board.
sc990 is a general software error. This error is often logged in conjunction with other errors, and may not necessarily represent a separate problem.
Your best bet is to check the hard drive first -- maybe try formatting it or replacing it if you have an extra one. Good luck!
Posted on Nov 19, 2010
zulkiflinakal
    New Friend:
    Problem Solver:
  • 3 Answers
Replace new one drum
Posted on Oct 08, 2011
Our gestetner 3502 as an error code sc990. How can I fix this?
Replace the drum if not possible then go to copy sp mode dial 2208 and change the copier sencer mode to pixels mode
Sep 13, 2017 | Gestetner Office Equipment & Supplies
Update firmware for MP 1600
SC990 means that the hard drive has failed..... It needs to be replaced with a new one or a hard drive from another copier of the same model. Or you can disconnect the finisher.
Jan 12, 2014 | Ricoh Aficio MP 1600 Black and White...
CODE SC542
press clear mode key follow by 107 and hold the stop/clear key to enter sp mode power the copier off and on if the problem reoccur replace fuser unit and enter mode and off and on the copier
May 11, 2013 | Gestetner 3255 3265 3270 3355 3370 5502...
Mpc2500 sc360
black TD sensor error ,
may be the machine pulled alot of toner
you can copy black paper to fix it
i am waiting your feedback
Dec 26, 2011 | Ricoh Office Equipment & Supplies
HELLO. what does the code sc990 means for my copier? i a nashuatec dsm622.
you can try by replace new drum,because i have done and its success exactly
Jan 28, 2011 | Gestetner DSm622 Digital Imaging System
After moving unit on dolley and down some stairs (gentle trip) getting an SC 496 message. Suggestions?
try to check that there is toner in bottel and then 2- check that sensor of toner collection bottel is active
Jan 09, 2011 | Gestetner - 5502 Digital Imaging System...
Sc990
sc990 is the software problem. replace the HDD of the machine and it should be fine. don't format the hard drive as it might result in laser error code.
Oct 22, 2010 | Ricoh Aficio 1035 Copier
I have A problem of SC990 in the ricoh aficio 2035/45 and also I get light copies and over tonning problem.
The light copies and overtoning is probably caused by the developer going bad. Do you have a service contract on your copier? It's likely time for a whole PM (preventive maintenance) procedure.
The sc990 is probably caused by the copier's condition as well. Once you have the PM done (or at least replace the developer, rebuild the photoconductor unit, and clean or rebuild the transfer unit) the sc990 codes should go away along with the poor copy quality.
Jun 19, 2010 | Ricoh Aficio 1035 Copier
Sc990 in ricoh aficio2045
sc990 is a non-specific software error. Many times a firmware update will fix it. In the meantime, turning the machine off and back on should reset the code.
If your machine is very dirty or hasn't been serviced in a long time, that could cause the sc990 code as well.
Apr 27, 2010 | Microsoft Windows XP Professional
322 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
