Question about MK Battery Golf Cart 12 Volt Sealed Gel Battery Size 17 12
How to wire a 12volt lights to a 36 volt system on an E-Z-Go golf cart
Posted by redvan807 on
lennieg2000
  • 692 Answers
All you have to do is run the positive wire from the lights to the positive post of one battery and the negative wire to the negative post of the same battery. You will be using just one battery to power your lights. Hope this helps
Posted on Oct 20, 2010
  • khark Aug 01, 2011
    You need to run the wires to two batteries to get 12 volts.
My golf cart has six, 6 volt batteries connected in a chain, positive to negative throughout. Can I connect an auxiliary light of some type to this power source?
the cart is wired for 36 volts operation so you would need a 36 volt bulb
or
you could put the wiring for a 12 volt bub across the terminals of 2 batteries so the negative wire will be on a negative terminal of the first battery and a fused positive wire will be on the positive of the second battery
the batteries are connected in series so the sum total of the voltage is the sum of all of the batteries
by selecting 2 batteries in series you are using the sum voltage of 2 batteries
Nov 24, 2017 | Golf
How do I connect 36 volt battery charger to electic golf cart?
Maybe you have an Ezgo cart? Black is negative, white is positive, and the small red wire is connected to the white inside the charger receptacle.
Sep 04, 2015 | Golf
Wiring diagram for EZ-GO Marathon 36 volt golf cart
Excellent......asking for a Golf Cart wiring diagram in a Water Heater posting board....
Works for me
I have a Westinghouse Nuclear Reactor I bought used from the USN. Can you tell me where I buy the Heavy Water for it????? Kroger? Safeway? Whole Foods?
Oct 20, 2014 | Water Heaters
36 volt ezgo
First of all, lift rear axle off the ground and place blocks or jack stands underneath. Check to see if you have 36 volts On your batteries. Now you want to run a jumper across the big cables on the solenoid. Press the accelerator and the motor should engage. Clicking is a pretty sure sign that the solenoid is bad. Please let me know if this is useful. I can further elaborate more troubleshooting if this doesn't solve your problem.
Aug 06, 2014 | Performance Plus Carts EZGO Golf Cart 36...
Trying to hook 12 volt lights to a 36 volt golf cart
The exact answer depends on what battery voltage you have but this hint will get you going.
Assuming you have 3 12v batteries, just wire to the first battery + - and you'll have 12 v. If you have 6 6v batteries, wire to the first + and the second -. If you have a voltage meter, you can verify the voltage of my suggestion.
This will work for lights and other resistance circuits but not for sensitive items like radios.
Golf cart batteries are series wired to get the higher voltage.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Sep 24, 2010 | YouTube Videos
Want to connect electric lights to ez-go electric golf cart. It is a six battery system and I want to simply add a front light and rear red light.
You said you have 6 batteries. Are they 6 volt or 8 volt? Hint-- 6 volt has three holes in the top and an 8 volt has 4 holes on top of the battery. Battery manufacturers recommend the use of a voltage reducer wired to the whole bank. This take the 36 or 48 volts down to 12 volts and is regulated. this is recommended so as not to stress just 2 batteries. If you have 6 volt batteries, you can use any 2 that are wired in series.
Sep 21, 2009 | Garmin Walking Cart Mount For Golflogix...
Radio installation in a golf cart
Each battery is 6 volts. You would have to connect to the 1st Battery 12 volts posiltive {+} side and the 3rd battery negative side[-]. Run the positive lead thru an inline 10 amp fuse , then to the radio.
Jul 22, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
MK Battery Golf Cart 12 Volt Sealed Gel Battery Size 17 12 Logo
566 people viewed this question
Top MK Battery Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a MK Battery Health and Beauty Expert? Answer questions, earn points and help others
