Question about Hughes SD-DVR40 210-Hours Video Recorder
IS THERE A CLOCK DISPLAY ON THE DIRECT TV BOXES?
I have an lg laptop with windows 7,and I can't get
Taken from Microsoft's site:
The display language is the language that Windows uses in wizards, dialog boxes, menus, Help and Support topics, and other items in the user interface. Some display languages are installed by default, and others require you to install additional language files. When you change the display language, it is changed for your user account and is not changed on the Welcome screen. If you want to set the display language for multiple users or the Welcome screen, see Apply regional and language settings to reserved accounts.
  1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  2. Click the Keyboards and Languages tab.
  3. Under Display language, choose a language from the list, and then click OK.
Direct link to Microsoft's site:
Change the display language
Hope this helps!
Sep 16, 2014 | Computers & Internet
Big sreen tv problem
Are you talking about the direct remote or the remote for the set?
The direct remote should be programable for most sets and most set remotes will program for direct boxes.
Mar 16, 2012 | Televison & Video
My main vga monitor has no signal until windows starts loading, but my secondary connection (hdtv) has signal as soon as i power on my pc. If i need to change my bios settings then i need to have my tv on...
It looks like you have your TV set as your primary display, you will need to open up control panel to change this. I'm assuming you're using Windows 7 (the process should be similar for Vista and XP).
Open control panel > Appearance and Personalisation > Display, and choose the "Change display settings".
There should be a button that says "Detect" or "Detect Displays". Click this button. You should see something like this:
http://dl.maximumpc.com/galleries/dualmonitors/Win7_ScreenRes.png
Click the icon which corresponds to the monitor that you want to make you primary display (the boxes numbered 1 and 2 represent your two displays). Since you have yours the wrong way round, you should click box 2. If any check boxes come up saying "do you want to make this monitor your primary display, say yes. You should then have your monitors the right way round.
Jun 03, 2011 | Galaxy Technology Galaxy 43GGS8HX3SPZ...
No problem - I hope!!!! Just need to know if Direct TV is compatible.
Direct TV is compatible with all TV's. Just requires the proper cable connections
Mar 10, 2011 | Televison & Video
Can not change date and time the clock is not highlighed and the date it has is 1/01/2006 5:52 instead of 9/27/2010 11:50 The next question is I can not program the direct tv remote for the imput
Your tv is needs a digital signal to set the time.
So if your just using an xbox or ps3 you will not be able to do it.
If you have your cable / direct tv hooked to it.
You should be able to go to the "Menu" button select it.
Then in the Menu display it should show a "time" box or clock icon.
If the Icon for time does not show up then you do not have the
correct connection.
I'm using the Dynex as a computer monitor, direct connect and I do
not get the icon for time.
Therefore I can not change the display time for the TV.
Hope this helps.
Sep 28, 2010 | Dynex DX-L42-10A 42 in. LCD TV
How do i enable the closed caption on my samsung tv/direct tv?
Correct solution WITH DIRECT TV is NOT going to SETUP MENU on your Samsung TV and enabling it, this won't work with Direct TV!! I'll walk you through it. Grab your Direct TV remote, hit "Menu", pan down to "Parental, Fav & Setup", next click "System Set-up", next click "Display", now at the top of the screen between "Preferences" and "Clock" is "Captioning", click on it, now the first box reads Captioning TURN IT FROM OFF TO ON! You now have Captioning.
Aug 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Programmin my remote
Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 You could try the one below..
I know the new HD boxes and DVR HD Boxes have the new remotes and they included Olevia on it and it works with the new models of Olevia's
Jul 15, 2009 | Olevia LT32HVM 32 in. LCD Television
Can't change the clock time
Best Solution posted Nov 6, 2008, by Guest -- worked for me. Wondering what the DST is? -- Daylight Savings Time. There will be a button at the bottom right in the date OFF. Apparently the TV Guide programing does not work that well, especially with the new Digital boxes now need to receive over the air TV and the TV Guide programing never worked with Satellite TV. Wil this feature ever be up dated? I doubt it. It would be nice to have the digital box and your dvr cycled together.
Nov 03, 2008 | Panasonic DMR-E85H DVD Recorder
Hughes direct tv receiver (director pack)
get new ones i just had 2 boxes replaced 1 was sd-hbh and the other was a hi-def box both were fried cause the nit wit that set up the system didn't ground the dish and we got a lightning strike that fried them.... i would call direct tv or whoever your sat provider is because mine were replaced for free with 2 brand new boxes.... and you should check to see if your dish is grounded it will usually be grounded to a water pipe somewhere in the area of where your multi-switch is located
Jul 22, 2008 | Hughes SDHBH DirecTV DTV Receiver
Clock
Press and hold the Direct EQ button (also Clock button) for 2 seconds, toggles between clock, calendar and CD info display.
Nov 22, 2007 | Pioneer FH-P404
Hughes SD-DVR40 210-Hours Video Recorder Logo
1,048 people viewed this question
Top Hughes Televison & Video Experts
Tom Chichester
anabel smith
anabel smith
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
