It looks like having bad (refill??)cartridges. Try original ones. The rollers are there to push the cartridge forwart in the machine on a timed moment to transfer the toner to the belt.
Already replaced all 4 cartridges with OEM Lexmark units. I've even tried swapping back to the last set of cartridges one at a time to see if the error will clear - to no avail.
Try finding out if the rollers in the front cover rotate. If they do you should hear a klikking sound in the front cover. If not there is a problem in the mechanics of the frontcover.
I found the Lexmark checklist for you:
Missing toner cartridge service check
1 Remove toner cartridge in
question. Holding toner
cartridge with developer
roller away from you, check
toner present sensor
actuators located on left
rear of toner cartridge. Are
actuators damaged?
Replace toner
cartridge.
2 Insert toner cartridge and
ensure toner present
sensor flag moves forward.
Remove toner cartridge.
Toner present sensor flag
should spring forward.
Does toner present sensor
flag operate correctly?
Go to step 3. Replace toner
present sensor.
3 Turn printer off and remove
I/O board shield. Is
cable properly connected
to I/O board connector
DCN2?
Go to step 4. Properly connect
cable.
4 Reconnect operator panel.
Turn printer on. Touch
negative lead of voltmeter
to metal bracket that holds
I/O board to obtain ground.
Touch positive lead to
DCN2 pin 2 to ensure 5
VDC is being supplied to
toner present sensor. Is 5
VDC present?
Go to step 5. Go to step 8.
5 Check voltage level on
DCN2 pin 1. Is 5 VDC
present?
Go to step 6.
6 Push toner cartridge fully
in. Check voltage level on
DCN2 pin 1. Is 0 VDC
present?
Replace I/O
board. If
problem
persists, replace
engine controller
board. See
Replace toner
present sensor.
7 Turn printer off. Check
cable for continuity that
connects DCN2 pins 1, 2,
and 3 to toner present
sensor. Also check for
shorted pins. Is cable
okay?
Replace toner
present sensor.
Replace cable.
8 Touch positive lead to
DCN13 pin 9 to ensure 5
VDC is being supplied to I/
O board. Also check pin 11
for 5 VDC. Is 5 VDC
present?
Replace I/O
board. Go to step 9.
9 Check cable continuity
between LVPS ACN1 and I/
O board DCN13. Also
check for shorted pins. Is
cable okay?
Replace LVPS.
This is what I found at Lexmark service information.
If the printer thinks that a non-Lexmark cartridge is being used, the Operator Panel will post a “32 Unsupported Cartridge” error.
This occurs when the toner key sensor is not tripped by the cartridge key. The Operator Panel will post a “32 Unsupported Cartridge” error.
Resolution:
A number of things can cause this error. The logical sequence for fixing this should be the following:
• Correctly re-install the toner cartridges and be sure that they are Lexmark keyed.
• Bend the tabs on the left side of the cartridge out slightly.
• Check the left side of the front door for proper seating, if bent too far out the cams will not push the cartridges into the sensor.
• Check the toner key sensor 12G7062 connection to the IOD1 connector DCN15. Re-seat the connector and replace sensor if necessary.
• If all else checks OK, replace the toner key sensor. A common failure is the metal hinge will be bent as illustrated in the picture on the next page.
I cann not send you the picture this way. If you need it please send me your mail adress
It's not reporting that a toner cart is 'not present' (it will do that if i take one out and power on the printer....so i know all of those sensors are working fine). The printer understands all carts are loaded, but for some reason, after changing cartridges to new ones - the machine says i have an unsupported cartridge. I've swapped each toner, one by one, with the old cartridge (that worked fine in the machine) and still get the error 32. Which means there isn't one individual cart that is causing the problem from what i can tell. I've dissasembled the front door and checked the electromagnet controllers, they seem fine. the gears all spin good with no gear tooth issues.
I simply think something got 'out of alignment' with the cams. do you know of any documentation on how they are supposed to be aligned?
