Open the hood, Locate the plastic panel at the base of the windscreen on the passenger side near the wiper arm. The panel is held in place with plastic tabs. Pull the center stems of the tabs upwards. You may need to use a needle nose pliers to GENTLY pull stem upwards( about 1/4"). Remove tabs. Remove panel. Once panel is removed the filter is visible and can be easily removed and new one installed. Reinstall panel ,reinstall tabs. push center stems towards panel to secure tabs.
