Coby MP-610  MP3 Player Logo
Question about Coby MP-610 MP3 Player
I have a Coby MP3 player MP610-4G SN 024090076167 that freezes up - approx 4-5 times per hour - I've used the reset button on the back and the problem still persists - what else can I do?
Posted by ckselissen on
Anonymous
    Problem Solver:
  • 18 Answers
I don't know that this will solve your particular problem but I just answered another similar Coby issue less than an hour ago, so I'm going to copy my recommendation here.
It sounds like the Coby operating system is corrupted.
I'm going to recommend you try the following procedure with one catch; I'm assuming you can turn the unit on and at least get a menu. If not this procedure isn't going to work.
NOTE: The following procedure will erase everything on your Coby so be aware!
Essentially, we're going to reformat the unit using Coby's own format routine.
1. Power Unit On
2. Scroll through your main menu going to your right. From "Music" ---> to "Settings"
3. Under "Settings" you will have another menu. Look at the bottom choice called "Sys Tools"
4. Select "Sys Tools" and you will have a series of options, choose the second option "Format"
5. Select "Format" and follow the prompts
6. Wait for the routine to complete
7. Power unit down
8. Power unit back up and reconnect to PC
9. Use Windows Explorer or My Computer to see if the unit is recognized, and it should be at this point.
10. You should be set
For some reason, the operating system for the Coby gets corrupted and this is the only way I know to fix it short of sending the unit in for repair, which isn't an option really. (Cheaper to buy a new one)
Hope this helps you or anyone else that has unexplainable problems connecting to the Coby MP-610 / MP-620.
Posted on Oct 19, 2010
  • ckselissen Oct 19, 2010
    do I do the quick or complete format?
  • Anonymous Oct 19, 2010
    Complete
    Keep in mind that this WILL ERASE everything that you had stored on your Coby, but it really doesn't do you any good if you can't use the player.
5helpful
CAN U PLEASE TOLD ME HOW TO RESET MY COBY MP828-8G
Hi asthondesulm...
Resetting the Player
Reset the player if it should freeze and not respond or
otherwise malfunction.
1. Disconnect your player if it is connected to a
computer.
2. Use a paper clip to gently press the Reset button located
on the bottom of the player.
For a user manual go to this website...
Please take time to rate me
http://www.cobyusa.com/files/manuals/MP826_MN.pdf
IPod freezes during use
The best thing to do wuld be to first, back up all of the stuff on your ipod, and the restore it back to factory setting through itunes. After that, you can put all of your files back on the ipod and it should function normally.
1helpful
3answers
I have a Coby Mdl.MP822-4g mp3 player.I turned it on. It went to the welcome window and stayed there. At the top of the screen is a right pointing arrow with the words PLEASE WAIT! It will not turn off...
Whenever I have a phone or an MP3 player that hangs like you have described, I update the firmware and this fixes the problem. You would not believe how common this problem is.
Unfortunately, there is no firmware available for your model at www.cobyusa.com.
There is a RESET button you can push and hold with a paperclip on the bottom of the unit, next to the miniSD card slot, so go ahead and try that - it may get its attention back.
If you have an sd card in there, I recommend taking it out.
Also, I have seen some players (like the sansa fuze) literally take hours to process new mp3 and video files when restarted once they are loaded.
If waiting for hours and the reset button do not fix the unit, please contact coby customer support at 1-800-727-3592 or [email protected]
I hope that helps.
3answers
Coby mp605-2g
My Coby MP605-2G is not turning on
I cant on my COBY MP-C7085
try pluging the mp3 player in a phone charger that plugs in the wall. make sure its the same plug that came with your player
1helpful
2answers
Error(4) what does this mean?
the first time when it was saying error(4) i tried to reset it and when i reset it, it took all my music files away. how do i get my music files back.
34helpful
12answers
Coby MP-C7095 Won't turn on
On my Colby player there is a small reset hole in the back. Mine has sometimes just stopped playing and shuts off. If you use a small wire (paperclip works well) push it in and reset it.
3helpful
4answers
Coby MP-C582 Will not turn on
These players are notorious for battery problems. Charge it all night and you just might get 30 minutes of use out of it before the battery dies. Make sure the slider switch next to the power button on top isn't in the "lock" position as the unit will not power up if it is. I recommend getting a 12 volt car charging plug for it and getting real aquainted with the tiny reset button on the battery side of it. You can get a plug for about $6 that will charge it through the usb cable that came with the player.
Frozen on coby red dot screen
i bout one of those and it wouldnt turn on 4 days after i got it so id take it back or something
12helpful
9answers
Coby mp3 doesnt turm on
Get a thin object like a needle or something and poke and turn in the small reset hole on the back bottom right.. SHOULD WORK FOR Mp3/Mp4 Coby 2GB PLAYER
Top Coby Audio Players & Recorders Experts
Marvin
Marvin
Morne Olivier
Morne Olivier
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
