Question about Generac Guardian Series 5502 10 kW Emergency Power System 5502
Hi: I have a model 0052411 Guardian generator that is putting out 170 volts. Anyone have any idea what has caused this to happen. It has fried any transforms that are in the house. Generac is not much help. Let than 50-60 hours on the unit. Most likely the voltage regulator. Thanks
Posted by inlaws8 on
dan turkstra
    New Friend:
  • 44 Answers
Check the automatic voltage regulator .Or if you have a bad neutral connection one leg will be very high and one leg low causing damage to sensitive equiptment.
Posted on Nov 06, 2010
  • inlaws8 Nov 08, 2010
    Thanks Dan:
    Yes it was the voltage regulator. But my question was more to why there was not a fail safe sensor to shut the generator down. Why not a high voltage sensor?
I need a rectifier or avr for generac 3500 xl genarator
We supply multiple brands of generator set, such as: Cummins, Volvo, Deutz, Doosan Daewoo, MTU, Ricardo, Perkins, Shangchai, Weichai, Yuchai etc. The style of genset is varied, such as: container genset, trailer genset, portable trailer genset, soundproof genset, low noise genset, and silent genset, etc. Besides, we also supply design and construction of the noise reduction project up to the customer's requirements.
Jun 28, 2016 | Generac Electrical Supplies
Guardian rv generator troubleshooting. The fuse blowed while we was on a trip I didnt have one so I wrapped foil around the fuse (I know bad idea but it worked) when I shut the generator off the fuel pump...
Not knowing which model youa re talking about it is tough. Obviously NEVER wrap foil around a fuse ! All I can tell by your post is that power is on the fuel pump all the time now, I would say that you have damaged a control board.
Oct 01, 2013 | Guardian Electrical Supplies
We have a generac 10kw pad mounted generator and the battery has blew up two times now, what would cause this to happen? The entrie battery blows up into pieces. The generator has proper...
The battery is overcharging either by the external charger or by the engine alternator. This is causing the battery to "boil" realeasing hrdrogen gas. One spark or high current demand from cranking can cause this. Have it checked by a pro
Aug 10, 2013 | Generac Guardian Guardian 28" Battery...
Guardian rv generator starts popping when turning on hair dryer. Why does this happen?
What is the wattage of the hair dryer?. It sounds to that your hair dryer is drawing to much power for the generator.
Apr 19, 2013 | Generac Guardian Electrical Supplies
Coils on transfer switch got fried when utility came back what could have caused this
possible failure of a relay. contact generac,sometimes they will accomodate you with new parts
Oct 08, 2012 | Generac Guardian 200 Amp Transfer Switch...
Battery does not stay charged on my 20kw generac generator
WAS A 110 VOLT CIRCUIT RAN TO IT FROM THE NORMAL UTILITY POWER OF HOME OR BUILDING IT FEEDS?
NORMALLY THIS IS DONE IN A SEPERATE CONDUIT FOR CONTROL WIRES.AND THE FEEDERS ARE IN ANOTHER CONDUIT.
WITH A DIGITAL TEST METER,CHECK FOR 120 VOLTS AT THE BATTERY CHARGER IN THE GENERATOR CABINET.USUALLY THERE IS A RECEPTICAL TO PLUG THE CHARGER INTO.
IF VOLTAGE IS PRESENT AT THE BATTERY CHARGER AND INDICATOR LIGHTS ARE ON, CHANGE METER TO DC AND CHECK FOR 13.8 VOLTS OUTPUT FROM THE BATTERY CHARGER.IF YOU HAVE OUTPUT VOLTAGE TO THE BATTERY,AND IT IS DEAD,CHANGE THE BATTERY..
HOPE THIS HELPS YOU,BEST OF LUCK.....
Nov 01, 2010 | Generac Guardian Model 5784 20 Kw...
RPM/voltage fluctuation on Guardian Primepact 50G
go to www.zabatt.com - look in their Service manuals section - good luck!!
May 28, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
My Guardian 16KW
I have never heard that generators need to be perfectly level to prevent generator damage. It doesn't compute -- auto generators/alternators run at all sorts of angles -- so do motors. And for the damage to occur in 2 hours running doesn't sound right either.
It does sound like the generator itself is not working/generating properly, but I doubt it was caused by the slab.
Apr 29, 2009 | Generac Guardian Quietsource 25,000 Watt...
Generac Guardian Series 5502  10 kW Emergency Power System  5502 Logo
518 people viewed this question
Top Generac Guardian Electrical Supplies Experts
jdthefixer
Marvin
Marvin
epangan29
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
