Computers & Internet Logo
Anonymous Posted on Oct 19, 2010
Hi guys, i just got a thomson twg870 and i'm trying to connect to 192.168.0.1 but i can't find the username and password. I tryed with admin and "password" but it's not working. Any ideas? Thanks
  • Anonymous Nov 04, 2010
    @ nagie, it seems that my isp blocked somehow the access to the router, and i cannot do any changes :( they've told me that i need to put my own if i want to make changes.
    thanks to all.
    problem solved
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Oct 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
10848
Points
8
Try these: Username: admin Password: (leave Blank)
or Username: admin Password: admin
or Username: admin Password: serial number of router
or Username: Admin Password: (blank) etc...
  • Anonymous Oct 19, 2010
    done that, still nothing :(. Thanks anyway
  • Anonymous Oct 21, 2012
Anonymous
Level 2:
New Friend:
  • Expert 36 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
36
Questions
0
Helped
18833
Points
109
Pankystu,
The default username and password for most routers is:
username- admin
password- admin
OR
username- administrator
password-
Hope this helps.
-S
  • 2 more comments
    thanks but i tryed and it's not working. I also knew that most of them have the defauld admin and the password field blank but in this case is not working :(
    pankystu,
    Have you tried doing a hard-reset on the router (Pushing the small button located on the back of the router for ~10 seconds)?
    If not, attempt that and try using one of the default username/password combinations listed.
    -S
  • nagie Nov 04, 2010
    leave username blank and type admin as password. should work.
    username -
    password - admin
  • team42 Dec 09, 2010
    on mine it worked ( hard reset, then username- password- admin)
1helpful
I have just purchased a Thomson tg585v8 and am unable to log into the Thomson Gateway. I have tried all the usual defaults like; admin, admin; Administrator, Cp********, Administrator, "blank" etc. I have...
you do need to hold the button for awhile sometimes
Username: admin
Password: The serial number on the bottom of your router router. It begins with the letters CP.
this should get you in!!
2helpful
2answers
Default password
For D-LINK default password you can try one of these:
Username: admin
Password: admin
Username: admin
Password: blank (just press enter after typing in the username)
Username: admin
Password: password
1helpful
2answers
I have a thomson twg850 router but it won't accept my password, what do i do
Hello you might have to reset it and set it up again.
TWG850-4U Default IP: 192.168.0.1
TWG850-4U Default Password: admin
TWG850-4U Default Username:blank
Here is a guide:
http://compnetworking.about.com/od/homenetworking/ht/routerconfigure.htm
Good luck
4answers
Have gateway Thomson TG782T currently fixed connection. What do i have to do to go wireless ?
You need to enable the wireless capability of your router. Please read from page 29 of this manual.
http://www.thomsonbroadbandpartner.com/getfile.php?id=6978
You will need to know the administrator password of your Thomson TG782T.
1helpful
I need username And Password to Speedtouch modem
Usually the username and password for this are : admin for username and admin also for password. Sometimes the pasword is 1234. If someone change the password then you can hard reset the adsl modem by pressing and holding a small hole ( usually on the side, its in the manual ) using a pen or a pin. Then the username and password will be in its default. Just check the manual. Sometimes the username and password is also written in the box or underneath the adsl modem. If this does not work, you can try calling your ISP.
Password & username requested for site 192.168.0.1 Thomson say!
From what i remember the username is Admin/admin Administrator/administrator, the password field leave blank or if it requires one it will password or Password.
Regards.
3helpful
Can't get router username and password, can't reset router
Default IP of ST546 is 192.168.1.254
no username and password is admin
Default IP of DG834G is 192.168.0.1
username is admin and password is password
2answers
I have a Blitzz BWA711 router that I'm trying to configure but I don't know the default username and password. Anyway to find out the default account?
try this mate
username: admin
password: password
both in lower case
or tryin
username: admin
password: admin
hope it helps cheers
Needs password
Use default username and password, should be found under the router.
Try:
Username: admin
Password: admin
Username: admin
Password: password
Username: admin
Password: sky
Username: admin
Password: (blank no password)
Grand Canyon Tech
Grand Canyon Tech
