Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
[email protected]
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
Posted on May 07, 2010
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Posted on Jan 07, 2010
SOURCE: 10.1000 supply memory err0r
This is an issue with the black toner cartridge, replace the toner
Al
Posted on Sep 30, 2010
SOURCE: HP LASERJET M1522 NF 79
Hello i hope u 'll be fine.... thanks for using fixya.
NF 79 is actually an internal firmware error. It means
unit has encountered an firmware error internally.
To solve it try this
If printer is plugged in to a
surge protected extension lead then remove it and plug it directly in
to the wall socket.After it retry.
If this fails again, then replacement of formatter of the printer is best option.
Best of luck
I hope
this solution will helpful 4 u. Best of luck
Please
keep thumbs up in do rating
THANKS & Keep
using fixya
Posted on Jan 01, 2011
Aug 17, 2012 | HEWLETT-PACKARD LaserJet M1522nf...
Oct 18, 2011 | HP LaserJet M1522nf Multifunction Printer...
Jun 10, 2011 | HP LaserJet M1522nf Multifunction Printer...
Jan 14, 2011 | HP LaserJet M1522nf Multifunction Printer...
Oct 25, 2010 | HP LaserJet M1522nf Multifunction Printer...
Sep 21, 2010 | HP LaserJet M1522nf Multifunction Printer...
Jun 17, 2010 | HP LaserJet M1522nf Multifunction Printer...
Jan 07, 2010 | HP LaserJet M1522n MultiFunction Printer
Dec 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
Mar 09, 2009 | HP LaserJet M1522nf Multifunction Printer...
Jul 10, 2014 | HP LaserJet M1522nf Multifunction Printer...
