Question about Roland Vs-2000CD Digital Studio Workstation System
I HAVE A ROLAND VS-2000CD DIGITAL STUDIO WORKSTATION AN WHEN I TURN IT ON THE SCREEN SAY'S LOADING AND THE BAR DOES NOT EVEN GO A QUATER OF THE WAY IT FREEZE'S HAVE LEFT IT ON FOR A WHILE TO SEE IF IT WILL LOAD AN IT STILL WON'T LOAD HAVE UNPLUGED IT AN STILL NOTHING CAN YOU PLEASE HELP THANK YOU
Posted by downlow365 on
3 Related Answers
Anonymous
SOURCE: Roland vs 2000cd studio workstation/harddisk recorder.
Didnt work for me. HERE is the CONFIRMED fix for this issue straight from Roland. --------------------------------------------- It sounds as though your VS-2000CD's hard drive is fragmented and needs to be formatted. If you have any files and/or audio in your VS-2000CD that you need to backup, then our Roland Service Center can try data recovery. You may contact us at one the phone numbers below for more information regarding data recovery. If you do not have any files and/or audio that you need and you are willing to completely erase any and all files and/or audio from your system then you may apply the following steps to unlock your unit and format (erase) your hard drive: Unlocking the VS-2000CD Turn the VS-2000CD OFF. With the unit OFF, hold down track 4's TRACK/STATUS button as well as the FX2 button and then turn the unit ON--be sure that you are holding these buttons down BEFORE YOU TURN THE UNIT ON. Do not let go of these two buttons until the VS-2000CD has loaded completely. Once the unit has loaded up to the main screen you will need to format the drive; if you do not format the drive then your system may continue to lockup. If the previous step unlocks your system then please proceed to "HDD Formatting". If the previous step does not unlock your system, your hard drive may be malfunctioning and may need replacement. Please contact one of the phone numbers listed below for help regarding hard drive replacement. HDD Formatting: Hold down SHIFT and press F1(Project). Use the ZOOM buttons to cursor up repetitively so that you select drive "IDE:0". Press the PAGE button so that you are on page 4 of the Project Menu. Press F2 to select "FmtDrv"(Format Drive); you will then be on the Format Drive page. Turn Physical Format ON and turn Surface Scan ON. Press F5 to choose OK. ----------------------------------------------- Well this is the 2nd time I have had to find and perform this procedure. Hopefully it will continue to work when the project gets stuck, and not completely die to where I have to have the unit repaired. I love Roland, but this kind of thing is pretty damn scary. Tim Pearce [email protected] PS - Let me know if anyone needs other help technical or otherwise with the VS-2000CD.
Posted on Aug 20, 2007
Anonymous
SOURCE: insrtuction manual
I have a manual if you need a copy.
Posted on Apr 05, 2008
Anonymous
  • 23 Answers
SOURCE: "Setup Drive: Load Project -> Now working... -> Please wait...."
I have 3 2480s and I use them professionally so I think I can help you. Looks as if you need to install the OS for the system. It seems as if it lost. You should have the OS on CD and if not contact RolandUS and get one. You would put in the OS into your CD burner and power up the unit. I would recommend Roland HD support be on the other end if you are brand new. They will walk you through. I was one of the first to buy the 2480 when it came out and the manual is just insane to learn.
Mike
Posted on Apr 28, 2008
My roland vs 2000 says not found any drivers when i turn it on can it be fixed
I think your best option is to try downloading and installing the latest system update from the Roland Site link below.
http://www.rolandus.com/products/productdetails.php?ProductId=602
May 06, 2011 | Roland Vs-2000CD Digital Studio...
How do i return my roland vs2000 to factory settings
Call Roland's tech support, they will help you with anything you need. They're among the best in customer support 800-868-3737
Nov 25, 2010 | Roland Vs-2000CD Digital Studio...
Would like to setup Roland speaker DS-90A to Roland SV-2400CD
this is no problem. You can use the DS-90 through the analog outputs or the digital. Either will work well.
Sep 09, 2009 | Roland Vs-2000CD Digital Studio...
Roland VS2000 Doens't load project after power accident
turn it on and just let it load..it may take like 20 hrs or so but it will come on...and yea when it does you might not have anything that you had on there but you can start over and it will work like new..worked for me
C.D.
Mar 19, 2009 | Roland Vs-2000CD Digital Studio...
Roland vs 2000 no power up
check the powersupply on the board itself ensure that its not blown.
thanks,
Nate
Sep 03, 2008 | Roland Vs-2000CD Digital Studio...
I need to find a place to buy one roland vs 2480 cd replacement fader board
You should contact Roland to find out who their parts dealer is for your area. Once you are on their site, click on the Support tab.
Jerry G.
Jun 04, 2008 | Roland Vs-2000CD Digital Studio...
Mike
Apr 12, 2008 | Roland Vs-2000CD Digital Studio...
Insrtuction manual
Oct 11, 2007 | Roland Vs-2000CD Digital Studio...
Roland Vs-2000CD Digital Studio Workstation System Logo
153 people viewed this question
Top Roland Audio Players & Recorders Experts
Ekse
Eric Rotmil
Eric Rotmil
 Grubhead
Grubhead
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
