Question about Connex 3300 240-Channels Base CB Radio
Just need to know what are proper settings on my Connex CX 3300 HP. Thank you.
Posted by jlof304 on
Anonymous
    New Friend:
The proper setting depend on what you are doing with the radio at the time.
Here is a link for the owner manual http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Posted on Oct 19, 2010
Radio want stop scanning
your keyboard membrane is needing cleaned with IPA you must have spilled coke or pepsi or somthing conductive on its membrane so i would just look to replace it you need to perhaps replace some capacitors in the controller board section {mpu for it} i think dry caps cause this esp low value ones around the mpu
Apr 24, 2014 | Connex 3300 240-Channels Base CB Radio
Cx-3300 low output on low and high power
the switch for low and high power the contacts are gone or you need to check the DC voltage to the output section and the voltage drop on TX usually the likes of the cobra 148GTLDX has a bridge board you can remove and add some LCD DVM for current monitors and setting of bias etc so perhaps a regulator has failed or a resistor or the contacts on the switch you need to trace it out using current readings
Apr 21, 2014 | Connex 3300 240-Channels Base CB Radio
How do you dim display lights on a connex cx 3400 hp
O the front you should have a dim switch its on of 4 up & down switches ? if not check on the back ? was it bought as a new cb or was it 2nd hand as the dimmer switch may of been used for something else
Mar 09, 2010 | Connex 3300 240-Channels Base CB Radio
Need to know the normal use settings for the Connex 3300 HP. Changed trucks and wife cleaned the radio; I believe the settings all got messed up. Thank you very much.
turn the rf gain all the way uphave your pa fm am knob on am your band knob on your desired band hi rf power band hi or low depending on wich ever u want to uss
Mar 22, 2009 | Connex 3300 240-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
1,729 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
