If you are going to DIY and have proper tools and know safety precaution then please read on: Basic LCD monitor troubleshooting guide: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Replacement board: http://www.lcdrepair.us
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Vc6 luna, A visit to YOUTUBE should help you understand how you will investigate and possibly repair your very old E173FP display. The Switch mode power supply will be first thing to visually inspect for "bad" capacitors. If still require assistance, then return to fixya and read and follow link in the fixya profiles of "budmrtn" "12fixlouie" and leave additional info for us to read in a comment to this response. 12fixlouie
