Question about Cobra 19 Ultra II CB Radio
I want to be louder and i need to know instrutions on how to peak and tune my cobra ultra 3
Posted by dubspeakers on
Don Reiman
    Guru:
  • 773 Answers
Turn VR2 all the way to the side that makes your modulation full.
Posted on Nov 25, 2010
  • frank reyna Sep 14, 2012
    were is it located
What can i do to make it talk louder
good coax better antenna and the radio.you will have to look online for that information on peaking that radio.
Jun 14, 2014 | Cobra 19 Ultra II CB Radio
Cobra 18 wx st. peak and tune.
the only thing you can do is turn up the mod vari and thats it.
May 22, 2014 | Cobra 19 Ultra II CB Radio
How to tune and peak a cobra 18WXSTII
should never tune.they are tuned from the factory.Now peak thats different.The only thing you can do is turn the watts up or down and turn the mod vr up. you need a meter to do this.A schematic will also help.now have at it.
Feb 06, 2014 | Cobra 18 WX ST 40-Channels Base CB Radio
Wanting to know how to peak and tune my general lee hp cb radio
if you don't know how don't do it .If you turn the wrong pot you could kiss that radio goodbye.Find a tech and let them do it.
Nov 24, 2013 | Cobra Radio Communications
Cobra 150 gtl dx peak and tune
first off if you don't have the proper equipment to do this you will have a cobra 150gtl dx used in the box that you can use for a chock block. turn the wrong can and you will never be able to get it back to working order.
Jan 16, 2012 | Cobra 150 GTL DX Base CB Radio
I need more transmission range for free
A lot of people will say that you need to peak and tune the radio to get more range. And it will, but what it really comes down to is your antenna system.
Even with the best peak and tune, if you don't have a good antenna system, it won't do you any good.
You need to make sure the antenna is a good match. If you don't know what that means, then you should refer to your manual on SWR. The antenna has to be tuned so that transmit power does not get reflected back into the radio. If that is happening, all of the RF power is not leaving the antenna, and you are not getting out as good as you can.
Once you have a good antenna system, then you can worry about peak and tuning. But for a peak and tune, I charge.
Sep 04, 2010 | Cobra 19 Ultra II CB Radio
I want to know how to tune my cobra 19 3 ultra cb so that i can recieve and transmit
you can't tune the radio. You must tune the antenna. I have a generic thread which explains everything you need to know about tuning your antenna.
See here. Hope this helps you.
Aug 22, 2010 | Cobra 19 Ultra II CB Radio
I can not get out on my cb i can hear them but they can not hear me its a cobra
turn the mic gain all the way up. Make sure the antenna has been tuned for best SWR.
Take your radio to a CB shop and have them peak and tune it.
Mar 29, 2010 | Cobra 19 Ultra II CB Radio
How do you tune and peak a cobra 29 ltd classic and how many watts will it put out after it is tunned and peaked
i would highly suggest you take it to a cb shop to get a cb tuned and peaked. before you do that though, make sure you have a good antenna system. a good antenna will have a much greater effect on your cb than tuning and peaking. as far as output, who knows? it all depends on the skill of the person doing the tuning. be warned that any output over 4 watts is illegal and you could recieve hefty fines if caught with an illegal radio.
Sep 23, 2009 | Cobra 29 LTD CB Radio
How do i turn peak and tune my cobra 19 ultra 3 myself no cb shop close by
un-solder 1 leg of D11 diode, pull it out of the board, and make sure it does not short against anything.
That will bring your modulation up all the way. there are other adjustments that can be done, but without proper meters, you will most likely mess up the radio.
D11 will be a big step up any way.
Sep 09, 2009 | Cobra 19 Ultra II CB Radio
Radio Communications Logo
359 people viewed this question
Top Cobra Radio Communications Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
