SOURCE: front panel locked and remote don't work
Are you sure there is not a problem with the TV set? The set will need to be on to unlock the front panel. Bypassing the V-Chip Lock on most Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus. If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it. To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV. To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Good Luck
SOURCE: Toshiba 42H82 remote problem
Bad volume down tactil switch? Remove suspect switch and see----
SOURCE: 62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
[1] From the PARENTAL CONTROL menu, press the up or down arrow to highlight
Lock Fr. Panel.
[2] Press the right or left arrow to turn on (box has check mark) or off (box doesn't
have check mark) front panel lock.
OK.
Press the "Menu" button on the remote control, and scroll until you come to the "Preferences" menu. Select "Parental Control and Locks," then press "OK." If your TV does not have a "Preferences" menu, go directly to the "Locks" menu.
Enter the four-digit PIN that you selected when you turned the Panel Lock feature on. You may have to scroll up or down to access this area
Press the "Up" or "Down" buttons on the remote until you reach the Panel Lock feature. Move the cursor to select "Off," and press "OK."
Front Panel
Selecting this option lets you lock (disable) or unlock (enable) the TV's front
panel buttons. The remote still tunes to any channel so remember to remove
access to any remote that can operate the television.
1. Choose Parental Control from the Main Menue and press the OK button.
2. Enter your passworcd.
3. Press the down arrow to highlight Front Panel.
4. Press the right or left arrow button to choose unlock (_) or lock (_).
I don't remember my password and I want to unlock the TV
If you forget your password, you must reset it. Make sure the TV is of. Press VOL- (down) on the TV's front panel and then
CLEAR on the remote for approxhnately 5 seconds. The TV turns on. Enter a new password next time you access
the PARENATAL CONTROL menu or the TIME_menu.
