Question about Panasonic Cameras
I have a DMC ZS5 and I took pictures in the clipboard setting by accident. Can I get the pictures off the camera on into my computer? I tried connecting it through the USB port but nothing happens.
Posted by kmhumes on
Ty Price
    Brigadier General:
  • 11,967 Answers
Put the camera in clipboard mode...the rec/play switch to play. Now the clipboard menu is accessible and gives you the option to copy the clipboard to a memory card.
Posted on Oct 18, 2010
Panasonic DMC-ZS5 How to download pictures? Equipment needed ?
If you want to use a computer to read the internal memory or the SD card in the Panasonic Lumix DMC-ZS5, you will need the correct USB cable, which is an 8-pin micro USB (M) to USB A cable, . (One example: https://www.amazon.com/dCables-Panasonic-Lumix-DMC-ZS5-Cable/dp/B00448MAWK ) Then ensure that the camera is fully charged or is getting additional power (AC adapter or DC coupler). After connecting the camera to the computer, you should be able to transfer files from File Explorer (Windows) or the Desktop (Mac). This may depend on your OS, see page 140 of the Advanced Features Manual for the supported OS versions. (Check Windows compatibility for later Windows version compatibility.)
With Windows XP, Vista or 7, you can also use the PhotoFunStudio that came on the CD with the camera. There is an update to the software here: http://av.jpn.support.panasonic.com/support/global/cs/soft/download/pfs50.html . See the manual for using the PhotoFunStudio software.
The direct link to the Advanced Feature manual is ftp://ftp.panasonic.com/camera/om/dmc-zs7_adv_en_om.pdf .
I hope this helps.
Jan 24, 2018 | Panasonic Cameras
Does a chip on the screen of aTZ8 cause a fault on the photo
When you have a scratch on the display, your picture won't suffer. But if the sensor has a scratch all pictures will show that.
Just check a picture on a computer, and not on the back of the camera and you see what is wrong or not.
Jan 13, 2015 | Panasonic Lumix DMC-ZS5 / DMC-TZ8 Digital...
Regarding the Panasonic DMC-ZS5 camera: what is the default focal length set at when the camera is turned on?
The default is the widest setting for the lens. So, for example, if the lens was a 4.1mm to 49.2mm, it would open at the 4.1mm setting and you could zoom in from there.
Aug 29, 2011 | Panasonic Lumix DMC-ZS5 / DMC-TZ8 Digital...
All my pictures are gone off my LUMIX camera that I took only a few hours ago. The pictures ARE on my memory card, as it shows it when i put my memory card into the computer. But it won't show it on my...
First, it sounds like your mode dial is set to "clipboard". While it is, with no card in the camera, press the delete button to erase the clipboard memory. Then, set the mode dial to normal picture mode. Still, with no card in the camera, press the delete button again to erase anything from the internal memory of the camera. Then, insert the card and it should work properly.
Dec 24, 2010 | Panasonic Lumix DMC-TZ2 Digital Camera
I accidentally took pictures in clipboard mode and badly need to download them to my computer.. How... my camera is DMC FX40
In clipboard mode, there is a special menu. In this menu is an entry for "copy" which allows you to copy the clipboard contents to a memory card.
Dec 20, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
I can't transfer my pictures from Panasonic clipboard to pc
You need to transfer the clipboard pics to your memory card first. In clipboard "play" menu, go to copy. Select clipboard picture with left/right arrows and press "menu/set". Select "yes" with up/down arrows and press "menu/set".
Jun 28, 2010 | Panasonic Lumix DMC-TZ2 Digital Camera
Can't get images in clipboard off camera
In the "playback" menu, go to "copy" and select a direction (from internal memory to memory card) and click "yes" when it asks you if that's what you want to do. Once they're on your memory card you can transfer them to your computer using your camera and a USB cord or a separate card reader.
Oct 23, 2009 | Panasonic Lumix DMC-TZ2 Digital Camera
Cameras Logo
516 people viewed this question
Top Panasonic Cameras Experts
Ekse
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
