Question about Maytag Neptune FAV6800AW Top Load Washer
My neptune washer will start and run about half a cycle and it acts like it gets stuck and on one cycle and never shuts off. I put a load of clothes in before I went to bed and next morning the machine still said it had 23 minutes left on the cycle. So it stayed on all night.
  • aaron_davis Oct 21, 2010
    Already received a diagnosis, it was the control board. Thanks!
  • 526 Answers
What does half a cycle mean are you in Wash cycle, Spin Cycle? What does the Cycle Status LED indicate?
If you think the wash load is in a spin cycle of the wash cycle or rinse cycle place the machine in Spin Only cycle and see if it will complete.
Waht are your DIY skills? Do you want to try the repair/fix?.............Rich
Posted on Oct 21, 2010
  • FAV6800A FAV9800A
    FAV6800A FAV9800A Oct 21, 2010
    Sorry FIXYA won't allow my Cycle Status LED pic to post. It's below the main LED display...............Really great site.
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Spin cycle
    it sounds like there is either an obstruction in the pump, or the load is getting off balance during the spin cycle. two things to try, fill the washer with no cloths in it, when it starts to agitate, stop the cycle and put it in drain/spin cycle. the water should be out in under a minute. its hard to see because the door locks, but you can hear a difference in the pump when its out, or after 60 seconds, press cancel and open the lid to check. if the waters out in that time, the pumps ok. then run it through the spin diagnostic with a load of cloths. make sure the cloths are wet, and a normal load you wash. this will check to see if the load is getting off balance, and shutting down during the spin cycle. let me know if you still have the problem. good luck, shane
    Aug 23, 2009 | Maytag Neptune Washer
    Washer won't spin.
    Fortunately boards for most washers are cheap. Rebuilt board= $35 to 100: look online.
    But your washer probably doesn't have a bad board. It sounds more like a motor. Does the mother-in-law like to overload the washer so she can get out of your house faster? If your motor overheats there is a bimetal switch that must cool off before it will run again -kinda sounds like your problem.
    HonestDan
    Check my eBay auctions -ID= Jerrycia95*
    Jul 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Dc code appears only when clothes are in washer during spin cycle
    If it’s an FAV6800A I think you may have a clutch malfunction with your machine. To verify if the clutch has malfunctioned we need to perform a quick check. Please visit this link and review my post of Solution #1 posted on Jan 30, 2009. Steps 1 & 2 should get you started and give us some troubleshooting direction. Please post back with your results or if you have any questions.
    http://www.fixya.com/support/t1612027-maytag_neptune_fav6800aww_wont_spin
    Good Luck… Rich.
    Feb 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
    Door won't open
    you can take the 4 phillips screws out of the corners of your soap dispensor, the lid of the dispenser willlift up and youll see wrapped around in there eitehr a floresent green or orange plastic wire. that is a manual release cord for the latch assy. this will allow you to get your clothes from the machine, form there look into why the latch never released
    Nov 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Washer does not remove water in final spin
    If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
    First check that the drain pump, drain hose, and wall drain are free of debris.
    The washer may not spin properly if the drain system is not operable.
    Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
    If the washer hums but now drains, you fixed one issue.
    If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
    Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
    check all water outlets to make sure there is nothing blocking the pipes.
    you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
    Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
    Excessive wobble
    If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
    Sep 06, 2008 | Maytag Neptune Washer
    Neptune stackable washer...
    You put the detergent directly on top of the clothes.
    Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
    Maytag Neptune FAV6800AW Top Load Washer Logo
    394 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
