Expert
- Posted on Oct 18, 2010
Re: The screen says bookends and it cannot be turned off...
If the below Reset does not resolve your problem go to the link below this and click next to the right
http://www.apple.com/support/ipod/five_rs/classic/#
Reset To reset your iPod:
- 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
- 2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
- If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
- If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
