The F35 indicates a water level pressure sensor failure. A loose wire harness connection could be causing this problem if there is no water or suds in the tub. I recommend unplugging the washer and removing the top panel. Screws at the very back of the top panel secure it to the washer frame. Remove the screws and then pull the top panel slightly back and then up and off of the washer. The analog water level pressure sensor is shown in the first image below. The second image shows a clear picture of this component. Check the wire harness connection on this sensor. If you find a loose connection, secure the wire harness properly on the component then reassemble and test the washer. If you continue to get the F35 code, then the pressure switch will need to be replaced. I hope this helps.
also for the F-28 issue
http://fixitnow.com/wp/2011/06/30/how-to-troubleshoot-an-f28-error-code-in-a-whirlpool-duet-sport-washer/
ok...run unit on rinse and spin only,,we need cold water,,if unit still shows sud error make sure drain hose is not kinked,,,if we still have a sud condiction or error ,,remove toe panel and clean filter.good luck
Thanks for using FixYa. Error F 35 means Analog Pressure Sensor Failure- which means that there is a malfunction of the component detected by the Steamer Electronic Board.
1. Check that the pressure hose is fixed correctly. 2. Check that the air trap is not blocked. 3. Check that the hose is not blocked
If still the issue is not resolved then it is an issue with the water level pressure switch operation and there is a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch. Please do rate the solution if the issue is resolved or else post a comment for further assistance. Thanks Rylee
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
its junk and it should be a crime t sell to hard working people never did work good and it needs to go back across the ocean junk yard won even take it
Knowing from our washer, the SUD code is too much foam from the detergent. Since most soaps today are highly concentrated, or High Efficiency soap, try using less soap as a starter. :)
"F02" and/or "Sud" error are directly related to a common problem in this case. You have something clogging your drain line and/or drain pump. The error will not go away until you clear the problem. The following links explain how:
In some cases, the drain pump may require replacment. If something has been lodged in the pump reservoir for any period of time, sometimes the pump impeller can become damaged to the point where it does not pump water. Replacment pumps can be found at searspartsdirect.com or repairclinic.com. Just type in your model number inthe search menu. I hope this helps you resolve your problem and that you do not require parts. Let me know if you require additional assistance.
