Question about Karcher 2500 PSI Pressure Washer
What oil is used when changing the old oil - Karcher 2500 PSI Pressure Washer
Posted by ltipton on
Anonymous
Pressure washer oil
I took this picture of my power washer so it's easy to explain the oil.
The oil is different for engine and pump.
The pump oil is 20 or 30 weight non-detergent. SAE20 or SAE30 motor oil. The level of the oil comes up about half way. There is a plastic viewport on side of pump ... oil comes up half way on viewport.
The engine oil is 10W30 motor oil. It comes up about half way or a bit more on dipstick.
To remove oil from pressure washer, do not turn engine on it's side or turn engine upside down or motor oil will run into the carburetor. You might wonder how I know that. Afterward, the carburetor needs to be cleaned out.
To remove oil, you can tip engine to the side but not so much that oil runs up into top part ... to remove the rest of the oil, you can use a plastic hose
Posted on Oct 19, 2010
Engine oil turns black just a few miles after changing
Is ok for an oil to change his colour after changing, but depends in how many miles.
There are a couple of causes for that.
Keep in mind that you can't drain totally the old oil from an engine and that way your new oil will receive some black colour from the old one.
Also, the oil is going to the cylinders where are extreme temperatures and residues.
Maybe you had a to used oil in the engine or a bad one and you have deposits inside and the new oil washed those and received some black colour from them.
Next time before adding some new oil use a motor flush to clean it, but be carrefully when chosing it.
Nov 24, 2013 | Triumph Motorcycles
Oil pressure switch sending
you could have a blocked vain in the engine this would cause the light to come on. when changing the oil you should use oil change fluid before changing the oil it helps remove the old deposits and they get stuck in the oil filter.. then do the oil and filter change
Aug 14, 2013 | 2005 Opel Corsa 1.4
Golf mk2 gearbox oil change
Look for 2 plugs one lower to drain oil... one midway to fill.
Sep 05, 2012 | Cars & Trucks
Kia sephia 1993 when i should to change oil of the motor
Manufacturers vary on intervals recommended. However, the old rule is the best rule....change your oil and filter every 3,000-4,000 miles. If using synthetic (common ones available in stores) that interval can be extended to 4,000 to 5,000. More exotic synthetics (such as Amsoil, using their filter) run to 5,000 miles and replace filter and oil lost during filter change. Replace all oil at 10,000. Actually a good deal even though the oil runs about $10.00 per quart.
Apr 11, 2011 | 2000 Kia Sephia
I have a yamaha xt 660R 2008 with oil change at 1000 km in 04.2009 was used in 2009 3000km. In 2010 was used for 200km with that old oil.Now is 2011 that oil si very old. I want to change it but is bad...
Just change the oil shouldnt matter whether you change it cold or warm the bike up first.
I would probably do it cold, and the next change a bit sooner like 2000klms
Feb 26, 2011 | 2008 Yamaha XT 660 R
I need to flush out my oil and what kind of oil dose it take
I would use 10 W 40 oil in it. If you are in a super cold area use 5 W 30 in it. Castrol GTX is an excellent brand, you can use your personal favorite brand if you like. Avoid using store brands and stick with the brand names with oil. You will need to change the oil filter too when you change the oil, and you can get oil filters at any auto parts store. It is also a good idea, to change your air, and fuel filter regularly too. Figure out what you are going to do with your old oil before you drain it. Ask the auto parts store where you get the filter if they take old engine oil for recycling. Old 1 gallon milk jugs or old antifreeze jugs are great temporary containers to hold old oil.
Dec 29, 2010 | 1986 Dodge Diplomat
Oil change instructions and oil recommendation (lost manual)
Hello, oil to use in the engine depends on engine if it is a Kohler you will want to use 10w30 approx 2qts. The Briggs & Stratton engines use HD30 or SAE30 approx 1.5qts. Use the dip stick to ensure you have the right amount and don't over fill.
To change the oil:
  • run engine about 10 minutes to warm up oil so it flows better
  • at the bottom of the dip stick there is either a valve or plug
  • open the valve or plug and let the oil drain (I use an old gallon oil container with a funnel) leave the dip stick out
  • while the oil drains; change the spin on oil filter
  • once all the old oil has drained replace the plug or close the valve
  • wipe down the funnel and use it to refill the new oil
  • use the dip stick to ensure proper fill level
I also recommend that you replace the air filter at the same time, if the engine can't get air is can't run efficiently.
If this is helpful please vote yes, Thank You!!
Sep 15, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
I have a mazda 6 2 litre diesel eating oil, what oil do I put in? The oil light keep flashing the Mazda people told me it was the oil switch had that replaced and still eating the diesel like mad. The car...
Check your owners manual for the grade and type of oil. Probably a CD4 15W40. Make sure you use oil specifically designed for diesel engines...just any old oil will not work. Also, stick with one brand; each oil manufacture puts different additives which "flush" out of the engine when a different brand is used. It may take a couple of changes with the same brand, but you should see a decrease in oil comsumption.
Mar 26, 2010 | 2005 Mazda 6
How to change the oil
If the thought of performing your own oil sends chills up and down your spine, just relax. You can tackle your own oil change, saving both time and money. There’s no need to wait in line at your local service station and no cause to pay someone for labor. Just put your game face on, gather a few tools, and tackle it on your own.
Start your oil change by gathering several items. You’ll need motor oil - secure about four to five quarts. You’ll also need a new oil filter, old rags, a funnel, an oil-drain pan, a box wrench, and an oil-filter wrench. You may or may not need a car jack to perform your oil change. This depends on how close the bottom of your car is to the ground.
Let your engine cool off and locate the oil drain plug. If you have trouble finding your oil drain plug, refer to your vehicle manuals. Use a box wrench to remove the plug and let the oil drain into a pan. Once the oil is drained completely, replace the drain plug.
For the next step of your oil change, you’ll need to remove the old oil filter. Put the catch pan under it. Remove the filter with an adjustable oil-filter wrench and a counter-clockwise motion. Expect to get some oil on your hands; an oil change is a dirty job. Take one of your old rags and wipe the filter-mount area, checking to make sure the old filter’s seal isn’t stuck on the engine.
Take some of your new motor oil and use it to coat the rubber seal of your new oil filter. Don’t put too much on; you only need a very light coating. Install the new oil filter by hand. Typically, an oil-filter wrench is not necessary for this step. Keep it handy, however, just in case tightening by hand fails to do the job.
Now it’s time to install new oil. For this part of the oil change, you’ll need to find and remove the oil-filler cap. Look for it on top of the engine; refer to your car manual if you have difficulty finding it. Put the funnel in the exposed opening and pour the new oil into the funnel. Be sure to refer to your car manual to determine how much oil you’ll need to add.
After adding the right amount of oil, replace the oil-filler cap, turn you car on, and run your engine for a minute. Check to make certain the oil-warning light doesn’t stay on and look under the car to make sure oil isn’t leaking. Finally, use the oil dipstick to check the oil level. Use rags to wipe away excess oil; newspapers are good for this as well. Congratulate yourself, as you’ve just successfully completed your oil change
For any questions please go here and submit. For free diagrams or help just enter relevant information and we will respond with-in 24 hours.
Dec 09, 2009 | 1996 Honda Accord
Karcher 2500 PSI Pressure Washer Logo
1,065 people viewed this question
Top Karcher Garden Experts
Bruce Robin
Tim Venetis
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
