Question about Proview PL926WBi 19" LCD Monitor
SOURCE: Proview PL926WSi LCD monitor will not power up
try testing the monitor on another computer.
Posted on Oct 25, 2007
SOURCE: Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Posted on Feb 21, 2008
SOURCE: Preview 700 P
you should change al lthe caps in the PSU.. you can get them all from Maplins for a few pounds.
best get 105 centigrade ones
Posted on Nov 21, 2008
SOURCE: Proview 926 wbi monitor
There are online repair shop on eBay where you can send in your boards for repair. Just do a search on "PL926WBi" and you will find seller offering repair service. Sometimes its more then just replacing capacitor to resolve the problem.
Posted on Mar 21, 2009
Nov 14, 2015 | Kidde 4618 Firex Hardwire Ionization Smoke...
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Aug 25, 2015 | Zanussi Refrigerators
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Mar 24, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Jan 28, 2010 | Xerox XG-91D 19" LCD Monitor
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Oct 03, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Feb 16, 2008 | Computers & Internet
Dec 23, 2006 | Proview PL 566s 15" Flat Panel LCD Monitor
97 people viewed this question
sangel129, Did you even look with a magnifing glass or low power inspection microscope (5x to 20x) to find any possible "hairline thin", "thermal-fractured" solder connections of the active and passive components that are soldered to the "switch-mode-power-supply/ccfl inverter circuit board? Pay particluar attention to the power transistors that drive the CCFL inverter ferrite transformers. 12fixlouie
Finally i found the time to examine these monitors a little bit more i found the problem.
It seems to me that this is a cheap monitor, specially the fly tubes are very bad.
The monitor is 3 years old and the problem is that they drown more current than normal.
So the monitoring circuit suspend the operation of PWM IC (TL494). You can test the voltage at pin 1. Normal operation voltage , more than 2 volts, goes to 0.48V after 3 sec and the Back Panel lights go off.
I cut the traces that feedback the error signal, and the monitor work now for 2.4 hours but with reduced intensity form back light.
Thank you anyway
