Hi.my dstv remote control is not working despite showing a red light whenever i press any button.please help asap!thanx
Posted by jaymogithuku on
isiakajimoh5
    New Friend:
My dstv remote control function any time it likes.pls what is the solution it is a new machine.Thank you.
Posted on Sep 04, 2011
Michael Uhalla
Replace the battery with a new one as it's possible that the one in the remote control is bad.
Posted on Jun 02, 2018
How to reset explora remote
To set the remote to mode 3: press and hold both the i and BACK buttons for 3 seconds or until you see the green light blink on 1 and 2 (below the i and BACK buttons). The DStv Explora must be set up to "listen" for the correct mode. You can do this in DStv Central. Press the DStv button
Jun 29, 2017 | Computers & Internet
Dstv remote doesnt work..
Take your cell phone and turn the camera on, then aim the remote at the cell phones camera while pressing different buttons.
The infra red light will become visible and be flickering at different intervals depending on what button is pressed.
That is the start to see if it is even "TRANSMITTING".
Any infra red device that transmits will do this on a web or cell phone camera regardless of what it is.
They can see what we cannot with out eye!
Start there first if all coding fails and you still have the red indicator light working.
I hope this helped solve step one!
Robert W!
Jan 25, 2015 | Televison & Video
My TV is not responding when I press my DSTV remote
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Dec 10, 2014 | Televison & Video
Acs typh. invacare electric wheelchair, red light showing hand controls locked, cannot unlock it. please help asap.
Press the power button on then press the horn button twice before ten seconds. this should unlock the joystick
Aug 14, 2010 | Invacare Pronto M51 Power Wheelchair
PLEASE SENT ME ASAP THE PROGRAMMING INSTRUCTIONS FOR THE 538744 REMOTE CONTROL [email protected] thank you. asap!
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Thanx
Jul 28, 2010 | Brookstone 538744 Remote Control
Where is the code search button
The power button is used as code search button.
To programme the URC-3021 please follow the steps
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER).
5. To lock in the code, press and release SET.The LED will
blink twice.
6. Your done with programming.
Thanx
Jul 23, 2010 | One For All URC-3021 Remote Control
Can't get my jumbo universal remote to work with my sam sung tv model #LN22B350F2D
You can use CODE SEARCH SETTING for the Jumbo Universal Remote. Have you tried it?
This is an alternative method to programming your device without using the code list. The remote control will scroll through the list of codes to identify the correct code for your device.
  1. Turn onthe device that you want to set.
  2. Aim the remote control at the device and press and hold down the CODE SEARCH button for at least 3 seconds until the red LED lights up solid red.
  3. Press the device button for the item you wish to program, e.g. TV,DVD,VCR, etc. and the LED light will blink once and then remain solid red.
  4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to program shuts off. (Note: LED will blink once each time you press ON/OFF button).
  5. Once this occurs, press ENTER button to store the code and the LED light will turn off.
Thanx
Jul 20, 2010 | Innovage Jumbo Remote Control
I had my dish installed to one tv. Now i switched out the tv for another one how do i get my dish to work with the new tv
Hi there this is Kimberly Escobar with DISH Network. I will be glad to help you by providing you the information that can help you. To program the DISH Network remote with your T.V we usually integrate a code into the remote that works with the brand of your T.V allowing our remote to function with the T.V itself by reading your post you don't mention the brand of your television but that is not a problem there is another way to help program your remote without having to use a code, it is called Power Scan in the Power scan procedure we search for the code that gets the remote to control your T.V. To perform a Power Scan your T.V must be on, you press and hold the T.V button until all the other buttons at the top light up in red. Once they light up in red you enter the number 500, you wait for the top buttons to go off and the you will press and hold once again the T.V button until the buttons light up again once you see them come on you will press the big red Power button on the remote once immediately after you press the big red power button you will press one repeatedly the channel up arrow one time after another until T.V turns off immediately after it goes off press the pound button (#) you should see the T.V button light up 3 times then try turning the T.V back on using the remote it should work. Here is this link http://www.dishnetwork.com/SupportSection/power-scan-instructions it shows you the procedures. I hope you find this helpful if you have any questions or need further assistance please contact us directly at 1800-333-DISH thank you.
Jun 25, 2010 | DISH Network IR Remote Control
Technika tt-16 universal remote control codes for a beko tv
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
Nov 10, 2008 | RCA Universal Remote Control
Televison & Video Logo
14,095 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
