Setting the clock Use these instructions to set the clock. 1 Use MULTI-CONTROL to select CLOCK SET. 2 Press MULTI-CONTROL to display the setting mode. # Press BACK to return to the previous display. 3 Press MULTI-CONTROL to select the segment of the clock display you wish to set. Each time you press MULTI-CONTROL, one segment of the clock display is selected. Hour-Minute As you select segments of the clock display, 4 Turn MULTI-CONTROL to put a clock right. # You can also perform the same operations by
the selected segment blinks
pushing MULTI-CONTROL up or down.
Or you can get the manual on the link below. Page 25
http://www.pioneerelectronics.com/StaticFiles/PUSA/Files/DEHP3000IBOperationManual1023.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
