SOURCE: All channels locked out!!!
You might have to reset the scanner, refer to page 70-71 of your manual. If you need a manual go here,,,
http://support.radioshack.com/manuals/ome20-496.pdf
Hope this helps,,, Mechanic
SOURCE: I HAVE A PRO-2096 DIGITAL TRUNKING BASE SCANNER.
need to do a RESET. Then try your local WX frequency to verify it works. The RESET will wipe out all existing programming, just to warn you. Check your manual, or RadioShack.com for details.
SOURCE: MY 2096 BASE SCANNER READS ALL CHANNELS LOCKED AND
If all else fails, and it sounds like it has, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
SOURCE: I have a radio Shack
Hello waltz,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
1. Press the SRCH button.
2. Select the bank you want to clear all locked-out frequencies.
3. Press the FUNC, L/OUT. Lockout list will appear.
4. Press 6. Confirm list clear? 1=yes, press another key for no.
5. Press 1 to clear all.
I hope this solution was very helpful to your problem.
Thank you for choosing FixYa.
John
MY PRO-2096 HAS ALL CHANNELS LOCKED UP
TRIED EVERYTHING NOTHING WORKS
HELP HELP HELP
THIS IS AN EXPENSIVE RADIO
HELP ME MAKE IT WORK
hit lock out again one at a time
