Sylvania 6842PF 42 in. EDTV-Ready Plasma Television Logo
Posted on Oct 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The sylvania plasma tv does not have a coaxial cable connection, how do I connect my local cable?
CoppellTVRepair.com
Level 3:
  • Sylvania Master 778 Answers
  • Posted on Oct 18, 2010
CoppellTVRepair.com
Sylvania Master
Level 3:
Answers
778
Questions
0
Helped
396570
Points
1847
You just can't. Not without an external receiver.
Your TV is simply missing a piece of hardware - it is called TUNER - that can understand the signal that runs through the cable (or an antenna) and decode it into simple video signal.
So the only solution is to buy an EXTERNAL TUNER device (also called external receiver or external set top TV box).
Those are rather cheap compared with what they used to be, but if you care for an advice from professional it is: sell your TV and use the revenue towards the purchase of a new one. All TVs currently in the mainstream sales channels have that thing built-in.
Some of the older models that you will find on Craigslist (like yours) do not.
it is usually not a problem for users with cable TV because most cable TV boxes also have a built-in tuner. If you are talking about how to connect your TV to your local cable company then the right thing to do is call your cable operator and tell them you want a newer receiver that outputs standard composite (one yellow one red one white) or component (green, blue, yellow and white and red) - if your TV has the later.
Hope this helps. If it does please rate accordingly.
Cheers,
www.coppelltvrepair.com
I have an old Sylvania tv and it won't turn on
Here are some troubleshooting tips to try. However, as it is an older set, if these tips fail, the cost of a repair at a shop might exceed the value of the TV. In short, a new TV may be in the works. Cross your fingers. One of these tips may work.
Let's troubleshoot the issue and try to get it working:
If you are using a remote, check the batteries in it. If you are using several remotes with it, try the alternative remote. Sometimes there is a glitch affecting the remote for a Roku where it won't turn on the TV other than a powered black screen and you have to use the other remote to turn it off and back on and then the Roku screen pops up. I have not sorted out why.
Check Power Cord and Connections:
First, ensure that the power cord is securely plugged into both the TV and the electrical outlet.
If you suspect a faulty power cord, consider trying a different one.
Reset the TV:
While most Sylvania TVs don't have a dedicated reset button, you can perform a manual reset:
Unplug the TV's AC adapter from the electrical socket.
Press and hold the Power button on the TV for 20 seconds.
Plug the AC adapter back in and turn on the TV.
Check Audio/Video Cables:
Inspect the audio/video cables connecting your TV to the satellite or cable receiver.
Ensure that the color-coded prongs match their respective connecting points.
Correct any mismatches (e.g., white cable into a red port) by reorganizing the prongs.
Inspect Coaxial Cable:
Look for the coaxial cable on the rear side of the receiver, attached to the port labeled as ANT IN.
Confirm that the connection is firm; a loose coaxial connection can cause display issues.
Tighten the cable by pinching the silver band on the end and rotating it clockwise until secure.
Check for Interference:
If distortion continues on the TV screen, consider nearby interference.
Power-hungry appliances can cause electronic interference, affecting display quality.
Visit a Repair Shop:
If the above steps don't resolve the issue, you may need professional help.
Some technical faults, such as a blown fuse or faulty capacitor, require expertise in dismantling and soldering.
If uncomfortable with such tasks, consider visiting a repair shop
I get a weak or no signal message on my new Samsung plasma. I'm using coaxial to my cable box. The cable works fine because I can see the vcr when it plays. I have it set to cable on the right channel...
In this case, your VCR becomes the cable channels tuning device for your TV, the better connection should be from your cable box output to your antenna/cable TV input with the coaxial cable, surely, your TV has a better cable tuner than your VCR, to connect the VCR to TV you can use its AV outputs to an available AV inputs of your TV, you can get a better sound and picture in this way.
2helpful
How do you connect a coaxile cable wire to nec plasma tv that has no coaxile connection plug.
You need to have a decoder box from a over-the-air (DTV), cable or satellite provider that has an HDMI, "S" video, composite video, VGA or component video outputs to connect to the TV's input. The coaxial cable only plugs into the decoder box. Apparently your TV doesn't have a tuner for coaxial RF.
No coaxial connection
check if the LOCAL cable box has RCA out put, if not get this and hook up from the coaxial wire
http://www.radioshack.com/product/index.jsp?productId=2486501&CAWELAID=107592963
fosg2000
2helpful
Just got a Sega Mega drive, connected to my plasma
Most old systems such as Mega Drive will come with an RF adaptor, which plugs into the back of the console and has a coaxial tip on the other end, to connect to the tv.
When you connect the coaxial end to the tv, you connect it to the round coax plug which is where you used to plug in your old cable tv hookup. It also might say Ant. or Antenna.
Turn on your megadrive and use your TVs input selector to change to either "antenna" or "tv" or "cable" input, or until you hit the input which displays your megadrive's signal.
Tip: use your TV's view options to change the input to a 4:3 or "not stretched" aspect ratio so that your old Fullscreen video games will not be stretched out wide on your new widescreen HDTV.
Good Luck!
11helpful
2answers
My 42 inch sylvania plasma tv does not have a coax connection, so how do i hook up my cable to the audio/video connection? i know there is an rf converter to transfer audio/video to coax but i really...
Since your TV only has audio and video input jacks, you can connect those to audio and video output jacks on the VCR. Now connect the coax cable to the RF/ant input on the VCR and you'll have to change channels by using the VCR channel selector.
Let me know if you require further assistance.
Connect DVD to ESA PDP4294LVI plasma tv
coaxial cables are great for HD boxes and usefull components like that but as for D.V.D... dinosaur feed!
get a converter from "The Source" that will convert coaxial analog to yellow component Video and rca audio. and you will be laughing :)
Trust me i am the flat pannel guru! :)
Connecting the cable coaxial cable to a P50HDM VIZIO TV
yea wtf same prob here just want to put a indoor antenna now I got to go buy an external receiver booooooo!
2answers
Coaxial to component
You may need an extra HD tuner for your TV. The only problem that you may have would be the original signal running through the coaxial cable. If it's just regular TV stations, the tuner should fix the problem.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
