Question about Gaggenau DF 290-760 Built-in Dishwasher
LCD panel menu not working ... all buttons dead. Is there as reset button anywhere?
  • 2 more comments
  • bruce7747 Oct 18, 2010
    I AM IN A RENTAL CONDO FOR 1 DAY, THE DISHWASHER IS HARDWIRED. THERE ARE 42 CIRCUIT BREAKERS AND NONE ARE MARKED SO I AM UNABLE TO TURN IT OFF
    YES THE KEYPAD HAS LIGHTS AND POWER. I TOLD YOU THAT 17 SQUARES OUT OF 23 ARE LIT FOR OVER 2 HOURS. NONE OF THE CONTROL BUTTONS WORK.
    I HAVE HELD EVERY BUTTON REPEATEDLY FOR 15 SECONDS. I ALSO USED A HAIR DRYER TO HEAT THE LCD PANEL IN CASE IT MADE A DIFFERENCE BEING WARM. I
    STILL HAVE THE LIT SQUARES AND NO BUTTONS WILL WORK AND I CAN'T EVEN
    SHUT OFF THE POWER.
    I AM A HOME OWNER RENTING SOMEONES CONDO NOT AN ELECTRICIAN.
    I JUST WAITED 13 HOURS FOR YOUR RESPONSE WHICH WAS OF NO HELP.
    I WILL CALL A REPAIRMAN THAT SERVICES MY DISHWASHER. APPARENTLY
    THERE IS NOTHING FIXYA CAN DO.
  • 17,130 Answers
If the LCD panel is dead then the power supply section can be faulty . Unless the LCD panel and customer control switches react the set cannot be reset. So this is not a case for resetting but a confirmed failure.
Unless the power section is checked to the main board the fault can be failure of power.
So trace the power connection, check for failed leads or a possible fuse link in the power. Check from the power cord to the main switch and to the board.
Posted on Oct 18, 2010
  • Donald DCruz
    Donald DCruz Oct 19, 2010
    Sorry, beyond our control
  • Gaggenau Master
  • 3,247 Answers
I presume you have already tried to turn the mains power off and on again.'
When you say all buttons are dead does it also mean all the lights on the top of the panel are out?
Could be the controller has lost power.
Please confirm the situation.
Posted on Oct 17, 2010
  • Sam Oct 18, 2010
    In any case you will need to turn off the power if you are getting no response from the keypad. There is no specific reset button with these dishwashers.
    Are you seeing any lights on the panel?
  • Sam Oct 18, 2010
    sorry I did not know the lights on panel were up as the fixya system has more than one consultant dealing with clients concurrently and don't get to see the other consultants comments.
    If you are intending to use the dishwasher just for one day and assuming there are no user manuals left at the condo, it might be difficult to do much with it in case there is a fault.
    The dishwasher is made by Bosch and in some of the models one has to press each key for atleast 3 seconds to get it active. This is done to avoid accidental operation.
    I am assuming by now you would have pressed the key for more than 3 sec.
    I am still looking for the specific manual for your model and see if there is anything else.
    Good Luck.
I have akai 32 lcd tv its child lock is on its panel buttons are not working due to thisand i dont have the original remote to turn it on plz tell me how to slove this problem or factory reset it
You should have other button options on the side or bottom of your tv. Check all over for more buttons and find the one that is the menu option button.
Jan 18, 2015 | Akai LCT3201TD 32 in. LCD Television
SONY DCR-TRV285E lcd problems.view finder is ok but lcd not work i hav also repair control panel swich is not workor pls send me service manual page to gide me so pls gide me
I red the manual that came with the camera there is a reset button inside the lcd screen near the menu buttons its tiny press it with a tooth pick or wire you will have to reset the time and date after pressing hope it helps IF NOT check the menu settings good luck scottymac
Oct 19, 2011 | Sony DCR-TRV285E Digital-8 Digital...
How to reset the TV menu on my sanyo vizon 24k40?i think a menu pop out and someone in the house mess it up?can't access the whole menu and remote control isn't working?
Hold down "INPUT" Button at TV panel, while you press "INFO/A-B" button in your remote.. Or...Hold down "INPUT" Button at TV panel, while you press No.1 chnl on your remote..
Sep 04, 2011 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
I have a Epson lcd projector mp-x3 the lamp light is blinking so I replaced the lamp and the lamp light is still blinking and there is no light do I need to reset the lamp if so How do I do thatMukrray
Connect the power cable, power on the projector and then press the [Menu] button on the remote control. The configuration menu will be displayed.
Select Reset Lamp Timer from the About menu, and then either press the [Enter] button on the remote control or the [Auto/Enter] button on the projector's control panel.
Select Yes, and then press either the [Enter] button on the remote control or the [Auto/Enter] button on the projector's control panel.
The lamp operating time will then be reset.
Aug 11, 2011 | Epson EMP-X3 LCD Projector
Get a picture but no sound
Unplug,replug the tv about an hour later.Let the tv reset it self.Go to the menu,go to Audio setting,go down reset.The tv audio will work again.Not,than ur Tuner board is dead.Must be repalced.
Apr 26, 2010 | Sony BRAVIA KDL-32S5100 32 in. LCD HDTV
Menu not working.........
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Panasonic TC-26LX60 26 in. LCD Television
Samsung lcd tv
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 07, 2008 | Samsung LN-S2651D 26 in. LCD Television
Samsung lcd faults
Found this on FixYa and it worked:
I had a similar problem and the way to solve this is to reset the set from the remote. Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Peter
Mar 10, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
Feb 22, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Touch panel menu unaccessible
Me too! The camera was working perfectly until yesterday and when I turned it on today, it selectively ignores some buttons on the screen - and pressing the "Menu" gives me nothing. I've tried to reset it through that pin hole button, but it just resets the machine back to its default.
Dec 13, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
Gaggenau DF 290-760 Built-in Dishwasher Logo
605 people viewed this question
Top Gaggenau Dishwashers Experts
Stephen Krajewski
Level 1 Expert
ray gallant
barrybam
Are you a Gaggenau Dishwasher Expert? Answer questions, earn points and help others
