Sounds like possibly cold solder connections on the convergence IC's I believe there are 3 in your tv. They are easy to spot big black IC's that have STK392-xxx stamped on them.. If your lucky you can solder the connections and be back in business. Sometimes because of the bad connections left unrepaired it will cause the ic's to fail then they would need replacing. If you have soldering skills you might try yourself. Be careful and make sure its unplugged. If you arent skilled at soldering I wouldnt recommend even trying it.
