Dryers Logo
Posted on Oct 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ge dryer stopped workin its less than 2 years old... reset breakers and everything i also vacumed the back of it out where the hose goes in and still now working. is there a reset buton or whatd does this sound like?
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Oct 18, 2010
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10845191
Points
101584
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 • GE Dryers
Hello: I have a Maytag MDE9700AYM that was purchased three years ago but has been installed for less than one year. After the unit runs for 10-20 minutes, the circuit breakers trips off. Otherwise the...
It's possibly the circuit breaker rather than the dryer itself. Usually when it trips, it is overloaded or shorted. Overload can be a result of a loose connection or a bad heating element,when you remove the old breaker, see if it has some noticeable burn/corrosion marks where the wire is screwed down, I think replacing the breaker will fix the problem. Hope this helped Tim
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Freezer stopped cooling, less than 1 year old
Due to being less than 1 year old , you need to call a Whirlpool factory authorized service center for repairs . This repair will need to be done under warranty . You could try unplugging for a few minutes and then plug back in to reset the electronics .
GE Profile Model#DPSB513EBOWW Breaker kicked to
Have you reset the dryer breaker also. Even if doesn't look tripped turn off then back on again.
2helpful
GE Dryer shuts off w/ blinking and beeping
I just fixed that problem with mine. I tried many, many things. Final solution was vacumming out the holes in the rear of the drier. (Prior to that, I removed the lint filter and holder, checked all connections and vacummed out that area. I unplugged the vent hose to confirm there was no cluggs. I found resetting the breaker would work for about a half hour.) Just vacum out the rear of the dry. Not only will the beeping stop, but as an added bonus, you cloths will dry much faster!!!
My GE dryer DHDSR46EG 1WW less than 2 year-old dryer flips the breaker after about 10 minutes of drying
If the dryer appears to be running OK before the breaker trips, I might consider checking the breaker. Over time they can get weak and not hold the current rating.
If the dryer is smelling "hot" then we can look a little further.
Let me know.
Regards,
Aug 15, 2009 • GE Dryers
1helpful
3answers
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
My GE Driver will not heat
Check the circuit breaker or fuse box it takes two one to run one to heat. Then check thermostats Hi limit may be burnt if it overheated If the venting had been blocked. Hope that helps
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
