Question about Lexicon MC-8 8-Channel Amplifier
I have a Lexicon RV 5 receiver and I cannot get a video signal with the new Sony Blu ray player BDP BX 57. My Audio signal is fine. My old sony blu ray player works fine with the same exact connections. I have audio and Video when directly connected to the tv with a separate HDMI cable.
Posted by j_lamay on
1 Related Answer
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Lexicon RV-8 wakupe failure
Did you try this....
In the event of a power outage, the RV-8 will display a BROWN
OUT!! PRESS STANDBY message. To turn the unit on, use the
STANDBY button. For more information, see “POWER
MANAGEMENT” on page 3-3....
POWER MANAGEMENT ON, OFF
"Setup" >> "Power Management"
Opens the POWER MANAGEMENT menu, which is used to automatically
put the RV-8 into standby mode during brownouts.
When set to ON, the RV-8 detects low voltage levels or a momentary
loss of power and puts the device in standby mode. In the event of a
power brown out, the RV-8 will display a BROWN OUT!! PRESS
STANDBY message. To turn the unit back on, use the front panel
STANDYBY button.
When set to OFF, the RV-8 will attempt to function during a
momentary power loss, however software settings may become
corrupt and need to be reset.
When the RV-8 is in standby mode, pressing the button turns the
unit on and activates all zones that were active in the previous
operating session.
The RV-8 does not power on.
1. Make sure the rear-panel power switch is set to the | (“on”)
position.
2. Attempt to power on the RV-8 with the front-panel Standby
button and remote control On button.
3. Examine the power cord to ensure a good connection between
the rear-panel AC input connector and the wall outlet.
4. Check the electrical circuit and breaker.
Posted on May 01, 2009
Why won't it stream or play disk?
Call Kurtis: Why Your Samsung Blu-ray Player May Not Play ...
sacramento.cbslocal.com/.../call-kurtis-why-your-samsung-blu-ray...
KOVRSep 26, 2013 - Blu-ray players aren't the same as DVD players. ... disc compatibility issues arise and firmware updates for our Blu-ray players are ... My BD-C6500 is apparently one of those old blu rays that won't play blu rays. ... If you are viewing netflix streaming thru your samsung bluray then YES it definitely can. Its not ...
play mp4 files on a blu-ray player - MP4 - Streaming Video ...
www.tomsguide.com/answers/id.../play-mp4-files-blu-ray-player.html
Jan 9, 2014 - I see a lot of Bluray players will play mp4 files. ... If it won't do it via the USB port, will it do it if the mp4 files are on a DVD? ... player has a menu, items likeDisc Tray, Netflix (I use this menu choice to watch streaming Netflix), ...
Sony BDP-S590 3D Blu-ray Disc Player with Wi-Fi (Black)
www.amazon.com/...Blu-ray-Player.../B006U1YUZE
Amazon.com, Inc.Sony BDPS790 4K Upscaling 3D Wi-Fi Blu-ray Disc Player. 4.0 out of 5 stars 334 · Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player .... With the Sony BDP-S590, you can wirelessly stream music throughout the home to .... at internet.sony.tv as in the past some Sony products won't connect to certain services ...
Amazon.com: Sony BDP-S5100 3D Blu-ray Disc Player with ...
Jan 07, 2016 | Televison & Video
How can a make multiregion my sony bdp s2500
Sony BDP S1200 - Region hack ?. - VideoHelp Forum
forum.videohelp.com > Forum > Hardware > DVD & Blu-ray Players
Dec 14, 2014 - 13 posts - ‎7 authors
Hi peeps, My old Phillips Blu Ray gave up the ghost this week, ... especially bluray players. usually only the dvd side can be made region free. Sony BDP-S2500
Nov 30, 2015
Jan 26, 2010
Samsung BD-P2500 - All Regions Hack Required
Dec 1, 2008
More results from forum.videohelp.com
Multiregion sony bdp s2500 - Fixya
www.fixya.com/support/t25991992-multiregion_sony_bdp_s2500
3 hours ago - multiregion sony bdp s2500 - Sony DVD & Blu-Ray Players question. ... How can a make multiregion my sony bdp s2500 Multiregion. Dec 03 ...
Sony BDP-S580 multi region DVD hack with URC-3440 ' AVForu
Dec 03, 2015 | Sony Televison & Video
Sherwood RV-4050R compatible with new gear?
The TV is irrelevant.
BD would need HDMI, digital audio or 5.1 analog inputs on the contol receiver. You have none of these.
Jun 19, 2010 | Sherwood RV-4050R
HOW TO CONNECT A SONY BLURAY PLAYER BDP-S350 TO MY LG TV
One single HDMI cable will be enough, it will carry both the video and audio signals.
Jun 18, 2010 | Sony BDP-S350 Blu-Ray Player
I just hooked up a sony blue ray to Samsung HD TV and it worked initially and now the tv does not get a signal from Blue ray model BDP-S360
Please unplug the Cable from the Blu-ray Player to the TV.
Then, press and hold the STOP button on the Blu-ray Player for more than 10 seconds.
Then, connect the cable from the Blu-ray Player to the TV and check whether it helps.
Feb 21, 2010 | Onkyo TX-SR606 Receiver
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Jan 17, 2010 | Sony STR-DG510 Receiver
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Oct 09, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Sony BDP-S350 - no video..only audio on all outputs
This is button config for master reset without picture:
Home Left button x 3 Down button x 7 ok (centre button) ok Down button x 6 ok Left button x 1 ok ok wait a couple of seconds for settings to complete, when you switch back on you should have a picture and be back at language set up screen.
Hope this helps.
May 30, 2009 | Sony BDP-S350 Blu-Ray Player
Lexicon MC-8 8-Channel Amplifier Logo
62 people viewed this question
Top Lexicon Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Lexicon Audio Player and Recorder Expert? Answer questions, earn points and help others
