This is my 2nd Brother LS-2125i sewing machine. I have had the same problem that others have reported on this website. I am a very experienced sewer, so I know I am not using the wrong thread, needle, tension etc...First, the thread kept breaking. Now, the bobbin thread will not draw up. This problem started as the machine missing stiches. Then, as I tried to troubleshoot the problem, the more stitches missed until finally the bobbin thread will not draw up at all. I bought this particular machine less than 1 year ago. This is my last Brother brand of anything.
Make sure that the needle is fully up first and raise the presser foot. To access the bobbin, you need to remove the flat bed attachment that is at the front of the machine. This just rotates up and off the machine. Next rotate the shuttle cover down from the top of the cover. Now you can pull out the bobbin case towards you by the latch. This piece goes across the center of the bobbin case and to the right. Now you can remove an empty bobbin (if needed) and put the wound bobbin into the bobbin case to replace the bobbin.
Personally it sounds like it could be a costly repair.A new Brother LS-2125i can be purchased online for about $80.00. Most sewing machine repair places charge upwards of $60.00 for a tune-up. So it's your call? Good Luck
the thread goes in the front thru the eye of the needle & out the back of the needle
The brother website has free operation manuals
On the home page,, on the left hand side down towards
The bottom look for PRODUCT MANUALS
Click on it & it will take you to another page where you can
Pick your model number & download the manual
The loopy stitching is usually do to threading the machine with the presser foot down.
Raise the presser foot and re-thread or pull about 8" of thread through the needle and see if the loopy stitches go away.
This may also be the issue with the zig-zag stitch.
When the machine is threaded with the presser foot down, the tension is closed and the thread cannot enter as it should for the tension to control the flow of thread to the needle. The thread then feeds too fast and the stitching is distorted.
If the whole bobbin compartment is missing, you really need to take the machine back to walmart. They will exchange it and all will be good. :) Otherwise, Brother will have a website where you can get it but why put more money into it when it's the stores fault?
