Dishwashers Logo
Question about Dishwashers
THE anti flood device has been activated. I have emptied the salt tank, how do I reset the safety valve on the water inlet hose?
Posted by paulwilkins on
Raf Laenen
Dishwasher is Electrolux ESL64010. How do I reset the anti-flood since the error beeps 3 times.
Posted on Dec 11, 2014
DILLIGAF
    President:
  • 1,140 Answers
The answer is that you don't reset the anti-flood device. The anti-flood device re-sets itself when there is no risk of a leak. I don't really understand why you emptied the salt tank . . . ?
I cannot help you any further than this as you haven't specified your brand and model of dishwasher. If you can post these, I will try try to help further - if it's a model I support.
Posted on Oct 17, 2010
1helpful
I just bought a dishwasher SE34E200SK. The washing program always gets stuck in program 3 and it cant move further unless one has to turn it manually. Also it doesnot empty out the waste water after...
Hello
Most faults can be referred to the fact that the Anti Flood Overflow device has activated.
Modern day dishwashers like those manufactured that have a built in safety feature protecting the dishwasher against flooding. The technical term is 'Anti Flood Device'.
In the base of the dishwasher in the plinth there is a float switch. This is your 'Anti Flood Device'. In the event of your dishwasher over filling, the plinth fills with water, the float rises and actuates the switch.
Firstly, it will send a signal to the programmer device to notify there is a fault and output a message in the form of a code to some sort of display.
Secondly, the pressure switch acts as the water level indicator for the sump of the dishwasher so when the water level rises the pressure switch will activate the drain pump.
So before you consider throwing good money at new dishwasher, try doing a bit of fault finding your self and you might save yourself a ton of money.
Sep 10, 2011 • Dishwashers
5helpful
How do i fix error code AE on LG washer/dryer f1407adsp5
Hi.
Error AE is prompted when there is a leak detected at the base of the appliance or when the anti flood safety device gets activated.
Disconnect power by unplugging power cord or resetting circuit breaker.
While power is off remove any water present at the base of the appliance.
If there is no water, check the pressure switch, wiring and control board for faults that may result in error AE. Check also setting of the drain hose at the back (it may cause siphoning), and make sure that inlet valve is not leaking.
Regards.
Ginko
3helpful
Water supply to my Bosch SHE43CO5UC/17 dishwasher seems interrupted and not being supplied to the unit. Water supply to the unit is checked and confirmed available. What are the possible causes, i.e. stuck...
Could be a dirty hose filter or faulty inlet valve. Ther could be a leak and the bottom of the unit has flooded activating the flood safety which will cut the water supply. The pressure chamber and/or the hose pressure chamber to sumo could be block (take of left side panel and these are at the bottom right). Finally, the aquastop (grey box connected to the mains water supply that feeds the d/w) could be activated, faulty or fitted in the wrong position
Hope this gives you some where to start..
Srs4312gb constantly trying to empty sump even though empty will not start any other program
This seems to be that the Anti Flood system has triggered. This device detects water leaks / spills to the bottom of the washer and automatically puts the washer in pump out mode and shuts off the water inlet. The device is made up of a pollystireene float and micro switch that activates once the float detects any leaks / spillage. Dry water and check for leaks and this should solve the problem
Jan 23, 2010 • Dishwashers
Our dishwasher does not seem to be getting any
The anti flood device (polystireene plate and micro switch) when activated due to water leak on floor of washer, shuts off the water inlet valve and puts the drain pump on. Determine if any water has leaked to the floor of the washer and is activating this switch. Dry the water and rectify any leak. The water inlet valve (solinoid) could also be faulty although this is not common.
Jan 18, 2010 • Dishwashers
8helpful
2answers
Electrlux dishwasher - ESL 63010 - anti-flood
Got this tip from another board. Unplug and disconnect machine. Take machine out and tip 45 degrees to empty water in base of unit. Put everything back together. Thats it. Worked for me.
Dec 17, 2009 • Dishwashers
2helpful
Keeps flooding: pump comes on when switched off.
This sounds like an inlet valve problem, Replace it. Often a dirt particle gets in the valve.
2answers
Water inlet hose not letting water through to the machine
that's probably a flood-safe type hose ... most of them reset after you remove it and re-install where it connects to the faucet, but you have already swapped it . try removing it and reinstalling it , then turn water supply on slowly
3helpful
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
2helpful
Ariston ls2020 dishwasher dishwasher will not fill with water
anti flood device has been activated on inlet valve so appliance will not accept water
Jun 25, 2008 • Dishwashers
Open Questions:
Top Dishwashers Experts
Marvin
Marvin
